20 Most Recent HP DesignJet 2500cp InkJet Printer Questions & Answers
I have an HP DesignJet
firstly delete the printer drivers ,then reinstall them this will cure the problem goodluck
3/22/2015 6:40:22 PM • HP DesignJet... • Answered on Mar 22, 2015
0answers
67-1100
Be the first to answer 2/21/2013 5:16:11 AM • HP DesignJet... • Posted on Feb 21, 2013Be the first to answer
Designjet 2500cp error 010036 00000100
This can be caused by a faulty electronics module, trailing cables, printhead carriage assembly, or ANY of the stepper motors.
try this...
Switch the printer off from the back, and then disconnect the trailing cables from the electronics module.
Switch the printer back on.
If the error code changes to '010037'
If the error stays as 010036, change the Electronics Module.
If it is 010037, replace the trailing cables, then the carriage assembly.
Trailing Cable Part No. C4704-60015
Electronics module Part No. C4723-60114
4/30/2010 5:13:53 AM • HP DesignJet... • Answered on Apr 30, 2010
Hello. You probably have a worn out trailing cable. The manual says:
System Error: 010036 (see next page for 010036 0000XX00)
Problem Description: ADC Test Failure in the Main PCA.
Corrective Action: Try the following:
 Switch the Printer OFF from the back and
then disconnect the Trailing Cable from the
Electronics Module. Switch the Printer ON and
see if the Error Code now changes to “010037”.
If the error code remains as “010036”, replace
the Electronics Module �� page 8-6.
 If the Error Code changes to “010037” then try
the following:
Make sure that the Trailing Cable is
connected correctly.
Replace the Trailing Cable �� page 8-36.
Replace the Carriage Assembly �� page 8-42.
The manual can be downloaded at: www.lpscomputer.com/ec/manuals.htm
4/29/2010 5:16:22 PM • HP DesignJet... • Answered on Apr 29, 2010
I am gettin a error 070104 055300E9
This is a firmware error. Possible causes are corrupt image file or defective firmware. Try other print files. If some work, then some are corruped. If none work, replace the firmware. Call 800-959-1575 for firmware.
4/26/2010 9:31:31 PM • HP DesignJet... • Answered on Apr 26, 2010
Printer head contact error.
no. sorry Rick but i think you really need to replace the carriage assembly, if you can find one. these printers are aged. hope this helped you.
10/1/2009 3:22:29 AM • HP DesignJet... • Answered on Oct 01, 2009
Hi Hp designjet t520 printer when i print the reportthe cyan color change his place with magenta color and yellow is dark thanks i need to help
check the catridges thier must be a mixing up of color when you were refilling the catridges
3/15/2022 4:11:23 PM • HP DesignJet... • Answered on Mar 15, 2022
HP DesignJet 2500cp InkJet Printer Logo
21 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
printer head contact error
  • Office Equipment & Supplies
