20 Most Recent HP LaserJet 1010 Printer Questions & Answers
There are 2 cause for this problem
1st possible cause is the fuser ( either resistance doesn't go to correct temperature, or temperature sensor is damaged and doesn't read the correct temp )
2nd formatter board needs to be replaced or the main chip needs to be replaced
HP LaserJet 1010... | Answered on Mar 19, 2019
Try a hard reset of printer and/or reinstall the software, Check cartridges for ink and operation.
HP LaserJet 1010... | Answered on Dec 02, 2018
buy the cilp or senons
HP LaserJet 1010... | Answered on Oct 19, 2018
Try this link
http://www.fixya.com/support/t2995796-red_light_flashing
HP LaserJet 1010... | Answered on Sep 24, 2018
im kosova drvers hp laserjet 1010 pleas
HP LaserJet 1010... | Answered on May 02, 2018
Try disconnecting power (not just shutting it off) and data input. Reconnect power and start over again. Something else to check: Look at device status. There may be documents jammed up in queue. I had to abandon my 1010 when upgrading to Windows 10; there was no compatible driver!
HP LaserJet 1010... | Answered on Mar 18, 2017
hi..
ijust solved this issue
WHOA ...
my printer is HP 1020,, and i was printing a huge number of sheets, which USED TO GET STUCK IN AGAGIN AN AGIAN... coz, i was using a low quality damned paper..
now,, it began to gave error ,tht either the front cover door not closed , or its toner cartridge missing.
Well,, simple solution for me was (which is basic i think)
>> Remove the metallic plate on the back of the printer
>>there you 'll find , on the right side, near the socket for poer cable, a "lever" like thing, thats the lever for the "barrier" between the SENSOR... move it and u'll get an idea..
>> if its jammed ,, then free it..
(mine was stuck into dont know wht, and i freed it, and all is fine)
>> if spring adjusment is wrong, correst it(you may get idea by moving it again n again, whether it comes bbacl to its orgignal position or not...
> remore the tonor cartidge and insert it back while looking on the lever movements.... and you ll get whats the matter with it..
PLEASE note it,,, that i think,, the sensors are NEVER damaged !!! mind it.....my knowlegde says , sensors are hardly damaged ..
-----Adios.... Tauseem Omer...Ravian Kemcolian.
HP LaserJet 1010... | Answered on Jan 02, 2017
Not supported, purchase a new printer. This is a home printer, never intended for server environments. This is a host based printer and has no internal PCL board to convert print stream from current windows.
HP LaserJet 1010... | Answered on Dec 01, 2016
Try a different cartridge, blank horizontal would point towards a possible drum issue. Does the defect repeat down the page?
HP LaserJet 1010... | Answered on Sep 14, 2016
clutch unit problem .You should service
HP LaserJet 1010... | Answered on Sep 09, 2016
Fixya does not sell driver software.
HP LaserJet 1010... | Answered on Aug 15, 2016
Check your toner savings settings and adjust it accordingly.You may also experiment with the right kind of paper.
Regards, Mike.
HP LaserJet 1010... | Answered on Apr 07, 2016
Means that your cartridge is still functional but of older date. HP warns because the age of cartridge may negatively impact print quality. It is just annoyance, you should print without any problems. Regards, Mike
put hp Genuine Cartridge
HP LaserJet 1010... | Answered on Apr 04, 2016
check pressure spring
lubricate fuser under film
ensure well assembling
HP LaserJet 1010... | Answered on Nov 15, 2015
In my opinion it might be the lsu unit , or the high power supply is not having a proper contact on the cartridge
HP LaserJet 1010... | Answered on Sep 10, 2015
HP LaserJet 1010 Printer Logo
334 questions posted
Clive
Clive
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp lase printer 1010 driver
  • Office Equipment & Supplies
