20 Most Recent HP DesignJet 100 InkJet Printer Questions & Answers
0answers
0answers
Will not print color
If u USe The Printer Rarely , then printhead Nozzles Gets Dry ,Try Cleaning PRintheads Using Clean Printhead Option In Driver Maintenance
calibrate Printheads
9/16/2009 3:38:57 PM • HP DesignJet 100... • Answered on Sep 16, 2009
Printer rejects media "rear feed"
Hi
Thanks for using FixYa. The main cause for media rejection is the media loading process. Media can be rejected because of two reasons:
  • Loading through the bypass, the media is loaded with too much skew. Skew limit to load media through the bypass is 6 thousandths (.006) of an inch.
  • Loading through the bypass or loading media bigger than A4 through the tray, media is positioned to far away from the right side.
To minimize media rejection, follow the tips below:
  • Check that media in the tray is correctly placed, and adjusters are correctly set.
  • When loading through the bypass, check that media is correctly aligned to the right side and inserted completely inside the printer.
  • Always use the load button to load a single sheet through the bypass in the D-size models.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
9/14/2009 9:23:48 PM • HP DesignJet 100... • Answered on Sep 14, 2009
Quits printing magenta
Sounds like the printhead is kaput.
1/29/2009 1:02:55 AM • HP DesignJet 100... • Answered on Jan 29, 2009
Hi Hp designjet t520 printer when i print the reportthe cyan color change his place with magenta color and yellow is dark thanks i need to help
check the catridges thier must be a mixing up of color when you were refilling the catridges
3/15/2022 4:11:23 PM • HP DesignJet... • Answered on Mar 15, 2022
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
5/8/2020 3:49:18 PM • HP DesignJet... • Answered on May 08, 2020
HP DesignJet 100 InkJet Printer Logo
Popular Tags
14 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
hp designjet 100 not work leopard snow
  • Office Equipment & Supplies
