20 Most Recent HP LaserJet 4050tn Printer Questions & Answers
When I try to print avery 2181 labels from manuel
You need to configure your software for the paper size.Also in printer paper properties you can set up tray 1 for the required size
11/1/2013 5:29:02 PM • HP LaserJet... • Answered on Nov 01, 2013
Hp laserjet 4050tn error 79.4165
Every time I try to print I am finding it starts off fine and about half way through the page it stops with the error 79.4165. I remove the two pieces of paper and re start and it says ready again only to repeat the same problem. I was wondering if anyone can suggest what to do.Thanks,Jacqueline
1/28/2013 11:44:40 PM • HP LaserJet... • Answered on Jan 28, 2013
Cant print 4x6 cards on HP LaserJet 4050tn
Try opening the rear door and let the cards deliver in the back instead.
7/26/2012 4:28:40 PM • HP LaserJet... • Answered on Jul 26, 2012
50.2 fuser error
HiTurn the printer off and leave it asa such for 45 minutes and then turn it on.Check the fuser and make sure its properly and firmly fitted into place.This can get loose during shipment.Solved?Replace the fuser.
2/29/2012 7:12:00 PM • HP LaserJet... • Answered on Feb 29, 2012
What plugs ar needed
Required Power cable ,parallel cable or LAN network cable(if printer having net work facility) for data transfer from system to printer. Choose which is the best option for you, accordingly load the drivers, below link for drivers.select OS & down loadhttp://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=18324&taskId=135&prodTypeId=18972&prodSeriesId=25475&lang=en&cc=usParallel cable:1_1_2012_6_27_54_am.jpgLan network cable:1_1_2012_6_28_42_am.jpg
1/1/2012 6:29:31 AM • HP LaserJet... • Answered on Jan 01, 2012
I have a HP WINDOWS
You need to connect the printer with a cable to the wireless router. Then you must enter the printer menu and set an IP address, subnet mask and gateway corresponding to your NAT network or switch the DHCP option on (e.g. to get them automatically from the router). I suggest you to enter them manually if you are not going to switch the printer every day. Then in Windows 7 you must go to devices and printers, select Add printer, select local prinet and choose TCP/IP port from the list. After clicking next you will be asked for the IP address of the printer, you fill the one you entered in the device menu. Next you will be asked for the printer model and you must select it from the list or show a location with the driver. Click finish and a test page will be printed. Hope this helps. Alex
9/13/2011 8:50:40 PM • HP LaserJet... • Answered on Sep 13, 2011
I just moved my computer
Print a config page and check the IP address.
On the PC right click the 4050, go to properties, go to ports.
Make sure the IP address is the same as the printer.
Also on the rear of the printer, make sure that the green light on the JetDirect is on.
Check the config page (the 2nd page) right below the EIO X - JetDirect heading.
It should say "I/O Card Ready"
5/5/2011 5:47:01 PM • HP LaserJet... • Answered on May 05, 2011
I can not get it
Hiii,
From the following link you can download the drivers and can installed by selecting your operating system... hope your problem will be solved...
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=18324&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25475
1/3/2011 1:44:52 AM • HP LaserJet... • Answered on Jan 03, 2011
2answers
I have a Linksys wireless router and a HP LaserJet
go on this link and you willh ave wireless printer set up..follow the steps......http://h10032.www1.hp.com/ctg/Manual/c00312488.pdf
9/13/2010 8:43:20 PM • HP LaserJet... • Answered on Sep 13, 2010
HP LASER JET 4050TN PRINTER ON NETWORK SAYS IT IS
To do this, perform the following steps:
  1. Click Start , point to Settings , click Printers , right-click the icon representing the printer to be modified, and then click Properties .
  2. Click Ports , click to clear the Enable Bidirectional Support check box, and then click OK .
9/13/2010 8:36:49 PM • HP LaserJet... • Answered on Sep 13, 2010
The manual feed tray taking more than one page,
The seperation pad is worn out. order a seperation pad and tray 1 feed roller. you can usually pop out the seperation pad with a small flathead screwdriver and the new can be clicked in its place. the feed roller has a blue tab that unlocks it from the axle.
9/9/2010 5:44:03 AM • HP LaserJet... • Answered on Sep 09, 2010
Can't remove paper jam
open the cover and remove toner first and then slowly try to pull the paper.
1/29/2010 9:06:15 AM • HP LaserJet... • Answered on Jan 29, 2010
Is there a print counter on HP laserjet 4050 tn
Yes look in the info menu.
1/22/2010 5:48:13 AM • HP LaserJet... • Answered on Jan 22, 2010
Smeared print
Check the the fuser. Take the back door off the printer and unscrew the 2 screws holding the fuser assembly in the printer. The fuser on the 4000 series all use a teflon sleeve that can rip and cause the type of error you are getting. You can get a replacement fuser on Ebay for about $40-60 if you do find your torn.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
1/9/2010 4:22:34 AM • HP LaserJet... • Answered on Jan 09, 2010
HP LaserJet 4050tn Printer Logo
Popular Tags
29 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
print 4x6 cards hp laserjet 4050tn
  • Office Equipment & Supplies
