20 Most Recent
HP DeskJet 6840 InkJet Printer Questions & Answers
Connected HP6840 to iMac with
Hi there.
Actually you can. You can make it wireless if you have a wireless router.
Click this
link for the manual on how to.
Hope it serves you well.
Thank you!
Hp deskjet printer 6840 wont print .keeps on saying top cover is open when it is actually closed.
Pop off the right side cover - it is just held with clips. At the hinge, you will see that the cover switch arm that is supposed to move up and down as the cover opens & closes (in the slot in the geared hinge) is probably broken off. It is in the up position when the lid is closed, and down when the lid is open. I cut the shaft of a Q-tip to length and wedged it into the space to keep the cover switch up all of the time and still allow free movement of the lid. Geezer Geek
Trying to connect printer to
Once you plug in the printer it should try to install driver software. If it does not do this automatically then you can use the disc that came with your printer. Once this is installed try to print with Microsoft word or any other program and make sure the correct printer is selected. Hope this helps!
