20 Most Recent HP Photosmart 7450 InkJet Printer Questions & Answers
Looks like a braille text
Open the HP Printer Toolkit (this software was installed from the CD-ROM that came with the HP printer) and run a "cleaning cycle",
because some of the ink-jets are clogged, which results in the "all-white" horizontal lines, where some part of that line should be black.
9/15/2021 9:12:32 PM • HP Photosmart... • Answered on Sep 15, 2021
Why won't my printer print black text?
It sounds like you have a fault with the black cartridge print-head. Converting a document to pdf makes it a graphic and all graphics are printed in colour shaded with black even if your machine is set for grey-scale. If the black cartridge has built in print-head, take it out and try pressing the head to a tissue to see if it leaves a solid "footprint". If no footprint, dip the head into a saucer of hot water for a few seconds and re-test the footprint. If you get a solid line/bar of black the cartridge should be ok if not repeat the dunking but only for a few seconds at a time. If the cartridge is just a tank that plugs onto the printhead you will need to try a couple of cleaning or "diagnostic" cycles. If still no go try placing a folded up damp paper kitchen towel under the printhead for 5 minutes. Unplug the machine power cable while the machine is busy to do this. Remove the paper pad and repower the machine. Try a test page to see if things have improved. Good luck.
2/13/2018 8:45:58 PM • HP Photosmart... • Answered on Feb 13, 2018
Clean print head 7450
Using the photosmart software, choose Clean Printhead.
3/11/2015 5:55:44 AM • HP Photosmart... • Answered on Mar 11, 2015
Not printing to fast draft
Make "fast draft" your default setting, otherwise, whenever you open a new document, it will print it in "normal mode".
3/26/2014 9:42:32 PM • HP Photosmart... • Answered on Mar 26, 2014
My hp Photosmart 7450 printer was working, then in the middle of printing it stopped and there is an error message on my computer, the green light is blinking on printer but won't print
First things first... try connecting your printer to another pc or laptop and try printing... make sure spooling is on in the driver and there are no other programs running... if issue reappears then It sounds like your printer cartridges are the issue I would try reinstalling them... if that does not work then I would try cleaning your printer cartridge... Gather cleaning supplies: Clean distilled water. Use bottled or filtered water if distilled water is not available. Clean cotton swabs or any soft, lint-free material (coffee filters work well). Remove both cartridges. Unplug the printer. Lightly moisten the lint-free cleaning material with clean water. Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty. If that does not work then I would try ordering some new cartridges hp photosmart 7450 ink cartridges I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
9/12/2012 8:29:57 PM • HP Photosmart... • Answered on Sep 12, 2012
How to remove ink cartridge
open the printer door, find the cartridge you want to remove, and pull it out
5/16/2012 6:34:40 PM • HP Photosmart... • Answered on May 16, 2012
My problem is not solved
When the majority of the references indicated as "obsolete model" is very difficult to bring the references to their local area. I suggest visiting these links:
1.- SAMREM35 (SAM REM 35) - AH5910006M REMOTE CONTROL SAMSUNG SCM7450
2.- SAMSUNG SCM7450 Remote Control (Original) Hope helps. Your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using Fixya, and have a nice day.
11/7/2011 1:35:43 PM • HP Photosmart... • Answered on Nov 07, 2011
Printer pulls one page all
check for low ink level it need to replace the color or the black cartridge click on the printer status to see what cartridge is near empty, or you can check for pending job right click on the printer then open it if you can see that it has a pending job delete it all
8/9/2011 3:19:17 PM • HP Photosmart... • Answered on Aug 09, 2011
I have HP Photosmart 7450
Please describe more about your problem. If you've downloaded the drivers, have you installed them? That is, have you run the setup program for installing the HP7450 on the HP Pavilion computer? When you run the setup program, part of the process will search for the HP7450. Are you connecting with the USB cable and have you check that it is securely seated in both the computer and printer? Is your printer turned on so the computer can find it during the search process?
6/17/2011 5:07:10 PM • HP Photosmart... • Answered on Jun 17, 2011
Just tried to install the software for my hp
The Cd that you have might really not be compatible with the operating system that you have anymore.
Just download the latest software from the website.
1 Go to hp.com 2 Click on Support and Drivers 3 Enter your product name or number, in this case just type in HP Photosmart 7450 4 Hit go 5 Choose your operating system 6 Hit Next 7 Click on the link that says Driver - Product Installation Software 8 Save it to your desktop
2/8/2011 4:25:29 AM • HP Photosmart... • Answered on Feb 08, 2011
I just changed the ink
You should try a couple of ink cleaning cycles.
1/16/2011 8:27:24 PM • HP Photosmart... • Answered on Jan 16, 2011
HP Photosmart 7450 InkJet Printer Logo
117 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
ink cartridge work cartridges
  • Office Equipment & Supplies
