20 Most Recent
HP DesignJet 500 InkJet Printer Questions & Answers
Codigo de error 86:01
Carmotor.
Either something is jammed and preventing the print head carriage from moving from side to side, or the drive belt has snapped. Open the window and check the black belt that runs the width of the printer. Check both ends carefully because often the failure happens when the belt frays and gets wrapped around the motor or idler pulley.
Ffff ffff 030d0170
it might be a loose cable connection. check if your cable and wires are in order and in the right place.
ERROR CODE 11:11
Make sure the trailing cable is pushed all the way in (no bent pins) to both the back and to the printhead.
Push the carriage all the way to the right and turn the printer off and then back on.
My hp designjet 500 doesn't recognize the I/O Card
By I/O card I assume you are referring to your JetDirect or the optional HP/GL2 formatter board, your EIO devices?
If you have them installed and the plotter does not recognize them.
Shut down the plotter then remove the power cord from the plotter or the wall and wait 5 mins.
Remove ALL EIO devices (JetDirect / formatter).
Plug the plotter back in and restart the plotter.
Test functions of the plotter.
Shut down the plotter and then add back only the JetDirect.
Start the plotter and check the function, and check if the menu will allow you to setup the JetDirect.
If successful, shutdown again and reinstall the Formatter Card (if you use one).
Test functions and check the I/O setup in the menu.
The idea in a nutshell, remove the cards and add them back one at a time to see which one if any is bad and causing the I/O to shut off.
If this does not help, you may need to replace the plotters
Electronics module
Bump on carriage
We would need a bit more information.
Where and when does the bump occur?
