20 Most Recent
HP LaserJet 4350TN Printer Questions & Answers
49 4C02 error
turn off the IPP protocol, and turn off Multicast IPV4
The 49.xxxx errors are indeed related to firmware
and the formatter and can indicate faulty firmware or formatter... but
are almost always triggered by some kind of communication that the
machine doesn't know what to do with... thus generating an error.
Power fluctuations (not clean power), or random noise (RFI/static)
transmitted on network or printer cables can also cause this problem.
If your unit sits on a line of power that is shared with other devices
(another printer/copier or a group of computers or a vending machine or
cooler)... move it to a dedicated power outlet.
If it's caused by signals the machine is receiving, it can be tricky to correct.
Hi Sir / Madam
I am
It might be economy mode, go to menu >configure device >print quality> economy mode> make it on..
Prints over its self down center of page
If it is jjust one color. Replace that toner since the wiper blade is not working. If it any or all colors try taking out the fuser and seeing if the image is laft on it. The fuser is under the top panel.
Printing one line on every other page
I really would need to see a print file to know what is going on.
Set the printer driver to "Print to File", when prompted, name the file "line". The driver will append a .prn to the name.
The resulting file: "line.prn" can then be analysed using any Hex Editor if it is a PCL file or A Postscript error analyser if the job is in Postscript.
Also, fyi - I do not believe you have a simple margin error. But just to make sure, under page setup, make sure that you have the correct page size selected in the driver and the same on the printer.
Don
Hp 2200D laserjet dirty copies
Toner and the drum is all one unit it is more likely that toner got onto the transfer roller and some near the fuser unit. Best thing to do is turn the machine off open the cover and remove the toner cartridge.
Then Hoover (vac) the inside with a soft brush and clean out all the loose toner. Once that is finished install toner cartridge a run about fifty sheets through to get rid of any other toner. Suggest installing a new toner cartridge as well.
Hope this helps you and please rate me
Cheers J
Dirty copies
When you replaced the drum did you printed like 15 pages? Did you noticed any change in the ouput of the line did it fade?, if you are 100% sure that the cartridge is ok., then check the fuser and/or the transfer roller. Make sure that the printer is clean inside.
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps:
·Turn off the printer
·Wait for 30 seconds and then turn on the printer
·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced
·In case the error is still being shown, the Scanner/Laser assembly may also require replacement.
Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
