20 Most Recent
HP LaserJet 3380 All-In-One Printer Questions & Answers
Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
The panel on my laserjet 3380 says scanner erroe power off power
You need to clean the small mirror film. Repeatedly turning on and off
the printer will move the scanner head to the left. When it makes it to
it's final position remove the screw and using a qtip gently wipe the
thin mirror film next to the light bulb. This will clean the dust that
is causing the error. some say use alcohol on the qtip i never used it.
Once it's clean the scanner will return to it's original position and
resume function. return side glass and screw, and you should not have
that error until it's once again dirty.
Scanner Error - Power On > Power Off
Sounds like the scanner has died. Sometimes restarting can help out. If you can print try printing out the configuration page and let us know what the error codes are.
