20 Most Recent
HP LaserJet 4250dtn Printer Questions & Answers
60.02 error
http://304522.pdf/ This is a motor lifter error for tray 2. Most times the issue is caused by a small spring which comes off the motor or the chasis where it attaches. See the attached page and look at item 3 as that is the spring. If it is ok, then you could try loosening the screw which secures the motor and then tighening it again. Do so with the tray removed.
Hp laserjet 4250 error 58.20
1 Turn the printer off and then on.
2 Reconnect the connector between the air-temperature sensor (the bar mounted across the main cooling fan
on the left side of the printer) and the power supply.
3 Replace the air-temperature sensor.
4 Replace the power-supply assembly.
49, 4c02 error in hp SPAM I AM 1-800-532-4187
This is what the result for that error code is:-
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Offending command: image
This is a great "little" printer. If you can provide the number and exact wording on the display panel of the printer, we can solve this. It is possible you don't have enough memory in the printer to process the image. You can order more from HP.COM.
Why we get 50.2 error plz heip me
That error indicates a problem with the fuser in the printer. You will need to replace the fuser assembly to correct the error. Here is the information from the service manual regarding that error.
Hp laserjet 4250 feeds multiple pages through the manual feed tray
Hello,It sounds like the paper pickup roller and separation pad for tray 1 is worn and will need to be replaced. These two parts pickup the paper and weed the pages into the printer. When they get worn down they can grab more than one page at a time. The parts are user replaceable, no need to pay a big repair bill for something like this. The parts come in a kit with rollers and pads for tray 1 and tray 2 along with the instructions and it is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302Here is a picture of the roller and separation pad from the service manual.
I hope this helps you out.
