20 Most Recent HP PhotoSmart 7350 InkJet Printer Questions & Answers
The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
HP PhotoSmart... | Answered on May 06, 2019
Do you have the alternate software installed so you can use this on windows 7? I assume you do. If that is the case go to installed devices, i.e. printers and right click the printer icon, see if the ink level shows up in the tools menu..
HP PhotoSmart... | Answered on Jun 08, 2016
Look for jammed paper of some other object that might have fallen into the machine.....
HP PhotoSmart... | Answered on Aug 07, 2014
A quick look at the HP web site for this printer shows that it only supports Max OS X 10.6 and later. These versions only support the intel processor based macs. Your PowerPC mac is, unfortunately, obsolete as far as Apple and the peripheral manufacturers are concerned and is not supported.
HP PhotoSmart... | Answered on Apr 21, 2014
Buy a new printer
HP PhotoSmart... | Answered on Jul 03, 2012
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
HP PhotoSmart... | Answered on Jun 21, 2012
take this link to hp, select your operating system and select your needed drivers from the list.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=72886&lc=en&cc=us&dlc=en&lang=en&cc=us
HP PhotoSmart... | Answered on Dec 31, 2011
Hi Rick ,
did the cartridges alline after you put them in ? I know the test was ok , so lets go into your printer software and check under settings to see if the printer needs to be told it has new cartridges , write me back and let me know if this works , if not , i will readvise ..........................Good luck Roy
HP PhotoSmart... | Answered on Nov 17, 2011
Lots of Q-tips! I'd also use some small pieces of cotton cloth--be careful it doesn't leave strands of cloth in the bottom of the printer. I've had this happen and I just stuck with it until it got reasonably clean.
Oh--and warm water will work just fine. Most of the ink is water-soluble
HP PhotoSmart... | Answered on Oct 27, 2011
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
HP PhotoSmart... | Answered on Jun 30, 2011
HP PhotoSmart 7350 InkJet Printer Logo
109 questions posted
Clive
Clive
Thomas F. Schneider
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
hp photosmart 7960 cartridge replace
  • Office Equipment & Supplies
