20 Most Recent
HP Officejet 7210 All-In-One InkJet Printer Questions & Answers
Cannot save scan to pdf
Tip 1: Update to the latest drivers This is the most important tip. Download the latest driver for your scanner from the manufacturer website..
Tip 2: Reset your scanner If your scanner used to work in PDF Studio but stopped working: Turn off your scanner ...
Tip 3: Make sure scanner works in other applications
Tip 4: Try another scanner driver
Regards,
Will
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
My hp officejet 7210 won't
You may be able to download a Windows 7 printer driver for your model printer from the HP WEB site.
If there is not one available, then HP considers this printer too old or not compatible with Windows 7 and they want you to upgrade your printer.
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:-
http://welcome.hp.com/country/us/en/support.html
Clean print heads
I suggest uninstalling the printer, restarting and reinstalling, meanwhile disconnect the printer from the computer and the power.
If the printer still doesn't behave after it has been disconnected half an hour or so it is probably faulty, or the new cartridge might be faulty. My HP printer has a cartridge priming option that must be used after it has been idle for a while or a new cartridge fitted.
Fax Error Codes
ERROR 346
The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
I am trying to scan multiple pages and save as a
am sure there will be an option to save it as .jpg file..
save the desired files as.jpg format..
then use any of the convertion softwares to convert it into a pdf file..
one link is given below you can use it or google it..
www.topshareware.com/jpg-to-pdf-converter/.../1.htm
PRINT AN ENVELOPE 9 X 4 HP 7210 ALL IN ONE
Hi there, my name is Lisa and I'd be happy to help. I have checked the specifications for the Officejet 7210, and from what I can see, 9x4 envelope printing is not supported. Here are the 4 supported envelope sizes:
U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
I hope this explains what the 9x4 isn't working.
Feel fee to take a look at the specifications using the following link:
Printer Specifications for HP Officejet 7200 All in One Printer Series
I hope this helps.
I work on behalf of HP.
