20 Most Recent
HP PSC 2355 All-In-One InkJet Printer Questions & Answers
Printer cartridge keeps jamming
The unit may have a paper jam or stuck object inside, if you
have experience a paper jam error before, check the printer for any
object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Error load paper?? but already have paper!!
what i might do is to remove that application using control panel, add and remove software. uninstall the printer software disconnect printer from pc, reboot/restart, go to printers in control panel remove all printers listed, then make sure you have right software for your printer. shut down this time.reconnect printer cable and boot back up. reinstall the soft ware with printer on.
HP PSC 2355 printer gives
Disconnect the printer from the computer remove loaded paper, turn it off & disconnect it from AC for at least 30 mins.That should resove your problem.
HP PSC 2355 All-in-one printer powers up but does
I am not sure what your problem is with the power problem with the printer, but I might have an idea how you can fix your problem with communication. There is a web site called "DriverSupport.com" that has drivers that work. I must warn you though that they have a charge. If you don't cancel membership, they will charge $9.99 a month. I like the business, so I go ahead and pay the $9.99, as they keep all of my drivers up to date.
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Wont align small print.
Check whether you have a head cleaning option ,if yes then clean the printhead after cleaning process do your alignment process
Carriage jam error message
Open up the printer cover and clean the timing strip with alcohol (That is that little long strip that goes all the printer long from left to right and passes behind the carriage)
Error code Ox88108508. Printer starts to print
hhhmmm try to download a resstter for your printer model, cause that error code cud mean that some part of your printer has reach its limits, printers nowadays have a counter in it. if you cant find any resetter software for your printer you shoukd call the HP tech. support cause they are the only who knows the right key combination on your printer panel that allows the parts to be reset.
for more help visit
Cbr tech solutions
Wont print error message 165:hw_interrupt_hwv2.c also 0xb9000001
The error is indicative of a hardware error.
Remove the power cord, hold # + 6 (semi-full reset) or # + 9 (full reset) buttons, then connect the power cord again, wait 3 secs (or until "Initializing Full Reset" appears on the printer display) and release the buttons.
This will set the printer configurations to its factory defaults.
Reset: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 3
Underware menu: Press the * and # buttons (simultaneously), followed by 1 , 2 , and then 4
Clear and reset NVM RAM: Press and hold OK and Cancel while plugging in the power cord.
If none of those work, it will need to be returned to HP as a failed unit.
