20 Most Recent Miele S251i Plus Bagged Canister Vacuum Questions & Answers
2answers
0answers
Miele S2511 Vacuum Cleaner Manual
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Miele model by clicking the link below. Miele 251i Manuals You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Miele I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
10/25/2017 3:13:48 PM • Miele S251i Plus... • Answered on Oct 25, 2017
Fix the cord rewind on miele plus s25251i1i
you will need to but the wholw assembly
2/3/2015 10:55:10 AM • Miele S251i Plus... • Answered on Feb 03, 2015
Power can't be turn on
could be a bad plug end you can cut it off attach new plug. If that dont work new rewind or bad electronic board
6/21/2014 1:58:55 PM • Miele S251i Plus... • Answered on Jun 21, 2014
Cost to replace a motor on a miele s251i
Buy a new one. Motors cost almost as much as the unit.
5/6/2014 10:52:50 PM • Miele S251i Plus... • Answered on May 06, 2014
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
5/6/2014 7:07:45 PM • Miele S251i Plus... • Answered on May 06, 2014
Miele bag overloaded vacuum stopped
Have you tried changing the bag.
4/21/2014 5:50:53 PM • Miele S251i Plus... • Answered on Apr 21, 2014
0answers
0answers
0answers
0answers
0answers
2answers
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
1/24/2013 12:30:31 AM • Miele S251i Plus... • Answered on Jan 24, 2013
Miele S251i Plus Bagged Canister Vacuum Logo
57 questions posted
Top Miele Vacuums Experts
john h
Ngoro
jws1013
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Miele Vacuums
  • Miele Vacuums
Most Popular Question
cost replace motor miele s251i
  • Vacuums
