20 Most Recent
Vollrath 40744 22 Meat Grinder 1.5 HP 110V Anvil MIN0022 Questions & Answers
Stand cake mixer not working. No power when turn knob think water got inside. You think a fuse is out or something? Can it be fixed?
If your stand cake mixer is not working and you suspect that water may have entered the device, it's possible that a fuse or other electrical component may have been affected. Here are a few steps you can take to troubleshoot and potentially fix the issue:
- Unplug the mixer: As a safety precaution, unplug the mixer from the power source before attempting any troubleshooting or repairs.
- Let it dry: If water has indeed entered the mixer, allow it to dry thoroughly before attempting to use it again. Place the mixer in a warm and dry environment for a few days to ensure all moisture has evaporated. Do not attempt to use the mixer while it is still wet, as it can be dangerous.
- Check for visible damage: Once the mixer is dry, carefully inspect the external components for any visible signs of damage, such as burnt marks or loose wires. Pay close attention to the power cord and the area where it connects to the mixer.
- Check the fuse: Some mixers may have a fuse that protects against electrical issues. Refer to the user manual or consult the manufacturer's website to determine if your mixer has a fuse and its location. If the fuse is accessible, check to see if it has blown and replace it if necessary. Use the recommended fuse rating specified by the manufacturer.
- Seek professional help: If the above steps do not resolve the issue, it's advisable to contact the manufacturer's customer support or consult a qualified appliance technician. They will have the expertise and knowledge to diagnose and repair any internal electrical problems safely.
6/28/2023 2:58:09 AM •
Food Mixers
Answered
on Jun 28, 2023
I have a John Deere La 130 with a 21hp Briggs and Stratton and I have been turning the gas shutoff solenoid for 20 minutes and it turns but doesn't seem to be coming off!
The gas shutoff solenoid on your John Deere LA 130 is typically located on the bottom of the carburetor bowl, and it should be screwed in to secure it in place. If you have been turning the solenoid for 20 minutes without it coming off, it's possible that it may be stuck or there could be another issue preventing it from loosening.
Here are a few things you can try:
1. Apply penetrating oil: Spray some penetrating oil (such as WD-40) around the base of the solenoid where it screws into the carburetor bowl. This can help loosen any debris or corrosion that may be causing it to stick.
2. Use a wrench or pliers: If the solenoid has a hexagonal base, you can try using an appropriately sized wrench to provide additional leverage for turning it. Alternatively, you can use pliers to grip the solenoid tightly and turn it counterclockwise.
3. Seek professional help: If the solenoid still doesn't come off after attempting the above steps, it might be best to consult a professional technician or take your mower to an authorized John Deere service center. They will have the necessary expertise and tools to diagnose and resolve the issue safely.
Remember to exercise caution while working on your mower's carburetor and ensure the engine is turned off and cool before attempting any repairs.
6/20/2023 4:31:53 PM •
Food Mixers
Answered
on Jun 20, 2023
How to get mixing bowl to release for removal please?
Question edited for typo.
Two person job. Spray the locking lugs with WD40. One person holds the machine and the other turns the bowl anticlockwise.
Full 'make model (what it is)' is useful in these questions.
5/11/2023 9:15:04 PM •
Food Mixers
Answered
on May 11, 2023
