20 Most Recent
HP Compaq Presario SR1215CL (82916052980) PC Desktop Questions & Answers
RAM capacity ?
Memory Upgrade Specs for HewlettPackard Compaq Presario SR1215CL Computer. The HewlettPackard Compaq Presario SR1215CL Computer takes the PC3200 DDR SDRAM 184-pin DIMM Memory Type, and comes installed with 512MB (Removable) of Memory. You can upgrade your HewlettPackard Compaq Presario SR1215CL Computer to up to a maximum memory capacity of 2 GB Memory, the system has 2 Sockets to install Memory, already with 512MB (Removable) standard Memory installed. For best Compaq Presario SR1215CL Computer performance use the maximum amount of allowed Memory per slot for your Computer. If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
http://www.memorystock.com/memory/HewlettPackardCompaqPresarioSR1215CL.html
4/20/2013 10:34:31 PM •
HP Compaq...
Answered
on Apr 20, 2013
Installing new motherboard, processor, mem, and video adapter. Powers on but no post.
If the beep is a very high pitched tone, turn off the computer. Your CPU is overheating. The thermal paste may not be spread correctly on the CPU or the heat sink isn't properly installed. Otherwise, it's probably a memory error. This machine takes 2 GB of memory as 2 single GB memory sticks. Try booting the machine with only one DIMM installed. Try each stick individually before getting replacement memory.I hope this helps. Cindy Wells
1/27/2013 10:39:14 PM •
HP Compaq...
Answered
on Jan 27, 2013
The hard drive is plugged in and there is nothing showing on the screen
http://h10025.www1.hp.com/ewfrf/wc/product?product=438014&lc=en&cc=us&dlc=en&lang=en&cc=ushttp://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=438014Motherboard illustration and motherboard photo towards bottom of page.
http://www.playtool.com/pages/psuconnectors/connectors.htmlFirst thing to check is power. Check the 3 main voltage power rails.3.3 Volts, 5 Volts, and 12 Volts. (All are DC Voltage)Check with a multimeter.(In comparison two D cell flashlight batteries store 3 Volts DC)LED's can light, fans can spin, but there may not be enough power to turn the Processor on.1) If ALL if the LED's were on at once, they would use less than 1 Watt if power.2) EACH fan uses 2 to 3 Watts of power.3) A typical Processor can use from 51 to 125 Watts of power. Just depends on what Processor it is.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors[TDP = Thermal Design Point. Under this heading is stated what the maximum Wattage is, that the Processor can use Up To ]The monitor screen receives a video signal from the computer. When the monitor does Not receive a video signal, No Signal is shown on the monitor, or the monitor may go into Sleep Mode, or Power Saver Mode.For additional questions please post in a Comment.Regards,joecoolvette
10/8/2012 3:58:12 PM •
HP Compaq...
Answered
on Oct 08, 2012
Moved my desktp computer PJ506AA and it now will not turn on. Light in back is flashing.
Try re inserting the cables connected to your CPU, if it doesn't work,you need to open the CPU case and re-insert the IO cards inside, it might also needs cleaning inside but a technician might be needed to do the cleaning correctly, due to sensitive parts inside. Try to watch videos on how to insert IO cards on other sites, for your guide. Good day and good luck.
6/7/2012 12:20:34 AM •
HP Compaq...
Answered
on Jun 07, 2012
Computer freezes must unplug to restart, what can
The first thing I would do is check for Malware.
This type of infection causes computer slowness, freezing and sometimes rebooting.
You can get a Malware scanner for this from
this link.Download install and scan your PC. Follow the suggested removal for ay infections you find.
7/1/2011 5:36:39 AM •
HP Compaq...
Answered
on Jul 01, 2011
Desk top computer w/ SN:
The computer fan may be clogged with dust or may have failed. The computer monitors the fan and if it is not working it will not let the computer start. It is a way for the pc to keep itself from overheating. Unplug the computer and open the cover and carefully try to vacuum or blow out all the dust. Then with the cover off try starting the computer and watch the fans and see which one is not turning, it may start if there was a lot off dust. If not the fan may need to be replaced.
Thanks for using FixYa.
6/20/2011 11:20:56 PM •
HP Compaq...
Answered
on Jun 20, 2011
Runing out for hardrive, can
According to the specifications, the motherboard supports two PATA hard drives and two SATA hard drives.
You can install SATA hard drives to any capacity you want.
11/7/2010 5:32:57 AM •
HP Compaq...
Answered
on Nov 07, 2010
Internet would not work and then whole system
Not too much.It seems you had a corrupt HD do to a virus or other issues.depends on your OS you can try to get some "boot files" in order to try to boot back your PC. After that if you cant do it you will need to re-install your OS.
10/12/2010 5:14:23 AM •
HP Compaq...
Answered
on Oct 12, 2010
Compac presario CQ62
Hello
Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine.
usually F11 or F10.
others has DVD, check and see what you have of these two.
in the first one, you recover from a disk partition the whole OS.
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too!
but be aware you have to be more specific on model, and BIOS dates.
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
Hp 6830s
If the fan making a smooth spin, but the noise is too loud, then it means the fan is trying to dissipate the heat. Probably the air inlet and or the air outlet (also the fan itself) is dirty (or clogged) and you need to clean it up using a canned air.
You may need to open the case/body if the dust become a dust ball (and you need a tweezer and qtip to pickup the dust ball and clean up the fan blades).
