20 Most Recent HP Compaq Presario SR1350NX (PP196AA#ABA) PC Desktop Questions & Answers
Can't find jack control panel
HI, Click on the speaker icon in the task bar. Go to Playback devices. There you can manage your jack connections.
5/30/2017 6:13:04 PM • HP Compaq... • Answered on May 30, 2017
How can I improve the vga display on the presariio sr1350nx so it bter than 800 x 600 which is its max right now??
No...don't change settings through the BIOS. Start\Control Panel\Display...to change your settings. If you have NVidia, then you can make the changes in the NVidia Control Panel.
5/1/2014 7:51:41 PM • HP Compaq... • Answered on May 01, 2014
Display on 800 by 600 how can i improve
Go into control panel then display. Should be able to change settings.
12/23/2013 8:48:03 AM • HP Compaq... • Answered on Dec 23, 2013
How to change battery on the Moschino Diamonds are 4ever watch
Post to Watches Category for a faster response.
3/20/2013 3:28:46 PM • HP Compaq... • Answered on Mar 20, 2013
Wgere is bios battery located on compaq presario sr1350nx
can not miss it, big as a quarter-coin
3/27/2012 7:04:31 PM • HP Compaq... • Answered on Mar 27, 2012
My Broadcom802.11wireless lan adapter was removed
You can Try doing a scan for new hardware which can be done through the control panel and see if that picks it up
5/9/2011 6:00:06 PM • HP Compaq... • Answered on May 09, 2011
Compaq sr1350nx Well, just installed a
It IS the Power Supply cjshearer11.
The green LED light flashing is a diagnostic light now. The diagnosis is a bad Power Supply with a Gree LED flashing.
Secondly, notice how the accessories are unplugged, and the Green LED light is solid Green?
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is.
Compaq Presario SR1350NX?
Uses an Intel Pentium 4, Model 519 (LGA 775 processor socket)
3.06GigaHertz maximum frequency rate (3.06GHz 'speed')
533MegaHertz Front Side Bus. (533MHz FSB)
1MegaByte of L2 cache. (1MB L2 cache)
Can use up to 89 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_.2890.C2.A0nm.29
You press the Power On button. Inside the plastic Power On button is a Power On switch.
(Typical ATX power on switch,
http://www.directron.com/atxswitch.html )
The Power On button presses against the Power On switch making a momentary contact.
(The Power On switch is a Momentary Contact Switch)
This closes a circuit temporarily that has 5 volts present. The 5 Volt Standby power.
(The 5 volts is always present when the Power Supply is plugged into power)
The 5 Volts is directed towards a circuit within the Power Supply.
The Soft Power On circuit. (PS_ON)
This in turn 'excites' the Power Supply, and turns the Power Supply on.
(No pun intended)
The first chip on the motherboard to receive power is the BIOS chip.
(Chip and Chipset are slang terms for I.C.
Integrated Circuit)
Burned into the BIOS chip is a small program. The BIOS program.
The BIOS program looks to see what devices are installed, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP, and Windows Vista are two examples of an O/S)
Your Power Supply has a weak voltage power rail.
(There are three main power rails in the SMPS in your Presario computer's Power Supply.
{Switched-Mode Power Supply}
The 3.3 Volt power rail, the 5 volt power rail, and the 12 volt power rail)
Enough power to light LED lights, and maybe spin fans, (Or spin a few times, and stop), but Not enough power to turn the Processor on.
NO Processor operating, no finding the boot record of the Operating System, on the Harddrive.
Do you have a KNOWN to be good, compatible power supply in an unused desktop computer, to use for a test unit?
Someone you may know may have upgraded to a better computer, and have a working computer with a Power Supply that you could borrow.
Needs to be an ATX form factor Power Supply.
Form factor for a Power Supply refers to the size, and shape of the case, for one.
It also applies to the power cables coming out of the power supply.
The size and shape of the case is;
6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall.
Needs a,
A) 24-pin ATX main power cable,
B) 4-pin ATX +12 Volt power cable,
C) Enough standard 4-pin Peripheral power cables, for the optical drive/s (CD/DVD drive/s),
D) One SATA power cable
A) 24-pin ATX main power cable:
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) 4-pin ATX +12 Volt power cable: (Power for the Processor)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
C) SATA power cable: (Power for the SATA Harddrive. 15-pin cable)
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
D) Standard 4-pin Peripheral power cable:
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The ATX power supply inside that Presario, is probably rated at a maximum Wattage of 250 to 300 Watts.
Made by some generic Power Supply manufacturer.
Bestec, HiPro, or Delta.
Around 90 percent of the desktop PC's out there use an ATX Power Supply.
You can buy one with as much Wattage as you want, won't hurt the computer.
A computer ONLY uses the power it needs, and No more.
Regards,
joecoolvette
10/20/2010 4:47:36 AM • HP Compaq... • Answered on Oct 20, 2010
Instructions for Compaq presario TV tuner.
if your TV Tuner is a PCI device...
put it in the PCI slot of the motherboard..
then after the rebooting process..
install the hardware through the installation cd..
so that you can use better..
10/23/2009 6:50:55 AM • HP Compaq... • Answered on Oct 23, 2009
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
3/1/2009 7:20:50 PM • HP Compaq... • Answered on Mar 01, 2009
Monitor does not turn on
how old your monitor. check the all power cable. check vga cable. did your computer give 1 bip sound?
1/26/2009 4:40:53 AM • HP Compaq... • Answered on Jan 26, 2009
2answers
Turning my computer off
Assuming you havent hust pressed it and let go straight away, as that is a reset, if you have pressed and held until the pc has gone off, then there is a problem with the poer down, go to control panel>power options, click advanced button and at the bottom of the window it says when i press power button on computer, then give the instruction in the drop down list see below
12/7/2008 5:50:21 AM • HP Compaq... • Answered on Dec 07, 2008
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
10/27/2008 2:26:59 PM • HP Compaq... • Answered on Oct 27, 2008
Using a Barracuda 7200.11 SATA 3Gb/s 1-TB Hard Drive
i have problem finding reformate disk how do i download
9/25/2008 10:44:00 AM • HP Compaq... • Answered on Sep 25, 2008
2answers
Recovery discs aren't working on my hp cq60-615dx, what should I try next?
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
6/21/2017 5:57:29 PM • HP Presario... • Answered on Jun 21, 2017
Compac presario CQ62
Hello Most laptop or PCs, has a combination keyboard pressing keys, that invoque the restore routine. usually F11 or F10. others has DVD, check and see what you have of these two. in the first one, you recover from a disk partition the whole OS.
1/26/2017 6:41:46 PM • HP Presario... • Answered on Jan 26, 2017
Bios update fore presario 8000
Its all about go to HP page, and bios updates, the instructions are there too! but be aware you have to be more specific on model, and BIOS dates.
1/26/2017 5:26:29 PM • HP Presario... • Answered on Jan 26, 2017
2answers
Compaq presario sr5350f pc and i keep gtting windows is shutting down everytime i click the help button
You may have a virus, malware, adware, a browser hijacker, or pups (potentially unwanted programs). A. If your computer will boot and you can operate it ok... Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. B. If your computer won\'t boot, or can\'t operate properly after boot... Tap F8 when you are booting, select "Safe Mode With Networking". Download and install Malwarebytes and Superantispyware (Note: If you can\'t do the download on your machine, do it on a friend\'s, put them on a thumb drive, and install them from it). Then scan your computer with each program, and quarantine anything found. C. If this process finds malware, to keep stuff like that from coming back, I recommend you get the paid version of Malwarebytes.Good luckG
7/30/2014 9:40:23 PM • HP Presario... • Answered on Jul 30, 2014
Macerator is not working
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... BestBuy, MicroCenter, Amazon. Very cheaply priced, very functional. Even the generic brands. Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection. ? if your information is correct "power supply" If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
5/13/2014 3:47:40 PM • HP Presario... • Answered on May 13, 2014
HP Compaq Presario SR1350NX (PP196AA#ABA) PC Desktop Logo
16 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
pc will not power up
  • Computers & Internet
