20 Most Recent
Haier HSA04WNCWW 3.9 Cu. Ft. Refrigerator/Freezer in White Questions & Answers
Will not turn off. Thermostat control clicks but
Check for a small wire sometimes copper color that ends in a small bulb in the refrigerator. Then check to make sure this sensor is not unplugged from its source. This if the thermal sensor that measures temp in the refrig
Why haier freezer is beeping
Either way if you had the doors opened a lot, it should like you probably have frost build up preventing proper air flow. You'd need to pull everything out of the freezer and remove the lower back panel inside the freezer. If there is frost build up, you'll need to use a hair dryer to thaw all the frost out. The unit will continue to beep until the set temperature (0 and 38) are reached so that could take a while even after thawing out all the frost build up.
If removing panels sounds like more than you can handle, you can always unplug the unit for 24 hours and leave the doors open to allow the unit to defrost on it's own.
