20 Most Recent Electrolux ICON Professional E32AR75JPS 18.6 cu. ft. All Refrigerator with 3 Custom-Design Glass Shelves, Tri-Level LED Theatre Lighting, Smooth-Glide Drawers, Custom-Set Controls, Luxury-Quiet Design and Optional Trim Kit for Built-in Look Questions & Answers
2answers
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
9/27/2022 9:38:41 AM • Electrolux ICON... • Answered on Sep 27, 2022
2answers
I have an Electrolux upright freezer glfh21f8hwb. It runs for about 3 days, then shuts off and displays error code OF and shuts off. If I reset it with the temp control, it starts again and freezes, but shuts off again in a few days. I just replaced the controller and capacitor with OEM Electrolux parts because it wasn't working at all. With those new parts, it started working again, but now I am getting the OF code. Please advise.
Sorry but I know nothing of the new-fangled fridges and freezers with their codes, but what does tend to stop an appliance that otherwise works well is a lack of cooling air around the motor/compressor unit and when the unit works harder during the summer or in the depths of winter when the heating is full on the thermal protection can cut power to the unit. Cleaning dust and fluff, ensuring all the power connections are clean and tight and not generating heat and ensuring there is adequate air space between the wall and the unit.
9/19/2020 9:15:13 PM • Electrolux... • Answered on Sep 19, 2020
How do I disconnect the electrical to remove door on Electrolux upright freezer modelFFU21F5HWM
https://youtu.be/FzZS8TbGVxQ
10/13/2018 5:28:18 PM • Electrolux... • Answered on Oct 13, 2018
I have an Electrolux Intuition Chest Freezer. The
you need to clean the condensor coils with a brush or compressed air
7/12/2018 7:05:35 PM • Electrolux... • Answered on Jul 12, 2018
FRT21BW8DW0
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help Use this link for future/current reference I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/17/2017 4:22:36 PM • Electrolux... • Answered on Dec 17, 2017
Electrolux ER 7526 Bfridge freezer
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help This link will help you with parts. You will probably need to replace your cold control. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/16/2017 2:07:51 PM • Electrolux... • Answered on Dec 16, 2017
I defrosted my Electrolux intuition chest freezer yesterday and the red warning triangle on the lid won't stop flashing now. Why?
Check the temperature inside the freezer, chances are it just is letting you know it hasn't reached the correct temperature yet.
8/11/2016 8:53:22 PM • Electrolux... • Answered on Aug 11, 2016
Whats min f8
It is probably the thermistor, F8 is a thermistor error on most Frigidaire freezers... Frigidaire Freezer Thermistor 297110400
8/1/2016 6:37:14 PM • Electrolux... • Answered on Aug 01, 2016
Electrolux FFU14F5HWB has intermittent defrost issues
Thank you for your post friend.
I understand that you are having intermittent defrost issues with your Frigidaire refrigerator. Are you experiencing an accumulation of ice buildup, are you losing food? Defrost issues can be caused by a variety of things such as a defective defrost heater, thermostat or defective door gasket. I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to buildup.
If there is a miscommunication within your freezer, a reset can possibly correct this issue. I recommend that you reset your refrigerator by unplugging it for 10 minutes. I hope this information has been helpful. -NS
3/6/2015 9:24:20 PM • Electrolux... • Answered on Mar 06, 2015
How to set temperature on built-in freezer that is not part of a fridge
Well start by defrosting it. Empty out the contents and put the contents in a cooler and then switch it off. You may need to switch it off at the electrical control panel by flipping the circuit breaker. Once you have turned it off, use hot water to help remove the ice. Have plenty of old towels around for this as water will get spilled on the floor. Once it is empty and the ice removed you may discover a temperature control switch, but if not, just be prepared to repeat the exercise every 6 months or so. In any case it is not a good idea to run the freezer when it is iced up. Once it is emptied and cleared out switch it back on and wait 10 minutes before adding your stuff back. Sometimes freezers will heat up a bit before they cool down. Once you verify its getting cold, put your food back in it. Good luck.....RD
1/14/2015 1:33:38 PM • Electrolux... • Answered on Jan 14, 2015
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature. Most often the old freezer has three indicator lights. - Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual. In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping"..... Dado
1/6/2015 3:10:05 PM • Electrolux... • Answered on Jan 06, 2015
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance Allow the appliance to stand for 2 hours after installation. Plug in the appliance and switch on at the mains supply. Turn the thermostat control (B) to a midway setting and adjust the slider control, situated on the back wall of the fridge section, to a midway position between "MIN" and "MAX". The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside. To switch off the appliance turn the thermostat control to position "?" After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer. Dado
1/6/2015 3:00:55 PM • Electrolux... • Answered on Jan 06, 2015
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that: - Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running. - The problem with draining condensate after defrosting cycle which also leads to accumulation of ice. - Leaking gas from the cooling system (reduced cooling capacity) - Faulty compressor Dado
1/6/2015 2:43:35 PM • Electrolux... • Answered on Jan 06, 2015
What do the symbols on my Electrolux freezer mean?
That is the model number. The E means European. The w at the end means that it is white in color.
7/19/2014 2:56:53 PM • Electrolux... • Answered on Jul 19, 2014
0answers
Electrolux ICON Professional E32AR75JPS 18.6 cu. ft. All Refrigerator with 3 Custom-Design Glass Shelves, Tri-Level LED Theatre Lighting, Smooth-Glide Drawers, Custom-Set Controls, Luxury-Quiet Design and Optional Trim Kit for Built-in Look Logo
3 questions posted
Top Electrolux Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Freezers
  • Electrolux Freezers
Most Popular Question
electrolux door alarm
  • Freezers
