20 Most Recent KitchenAid Kitchen Aid KICAOWH Ice Cream Maker Attachment Questions & Answers
3answers
Blue liquid leaking from ice cream attachment
I have been debating as to whether to buy one of these ice cream units but it appears it would be a big waste of money. I wonder how to track if Kitchenaid has made improvements to fix the flaw in the unit.
4/6/2019 11:48:15 AM • KitchenAid... • Answered on Apr 06, 2019
0answers
3answers
Hello. Approximately one year
Hi.
That means that the sealing was allowing liquid getting inside the attachment gears, and now it is leaking lubricant from the ice cream attachment. I don't think that the unit can be repaired, the ice cream attachment is all in one block, and I have not seen any part being distributed.
This small appliances have 12 months factory warranty, call Kitchenaid after registering the appliance, you may still be able to validate the warranty. If warranty is gone, complain that the problem was due to factory defect and try to get a part exchange with reduced price on new replacement, or , since warranty expire recently, see if you can buy an extended service plan.
See: Customer Care
8/5/2023 5:52:51 PM • KitchenAid Ice... • Answered on Aug 05, 2023
KitchenAid side by side refridgerator: Making
No the problem is from the main control assecmbly which is located on the top of the fridge.
The posibilities are first the solenoid and then board assembly.
9/1/2010 6:16:36 PM • KitchenAid Ice... • Answered on Sep 01, 2010
I NEED A HB1114 ICE CREAM MACHINE MANUAL
https://www.manualslib.com/i/ichb1114e+cream+maker.html Try this site. Let me know if it works.
12/4/2023 12:34:16 AM • Ice Cream Makers • Answered on Dec 04, 2023
What is the black liquid draining into the ice-cream canister from the motor while making? And is it still safe to eat?
No make and model provided but.... Of course it isn't safe to eat!! It is likely a mixture of oil, broken seal dust and a little metal/rust creamed with a drop of condensation. 50 years as as a chef and I wouldn't serve that or eat it. Fix it or thrown the machine away! These machines are normally 20 years old and get used 3 times every 2 years.
7/5/2023 12:17:35 AM • Ice Cream Makers • Answered on Jul 05, 2023
Ice cream maker freezes and stops turning after only 20 minutes. I set the time for 60 minutes.
If your ice cream maker freezes and stops turning after only 20 minutes, there may be a few reasons for this. Here are some things to check: Freezing temperature: Make sure that the temperature in your freezer is set to the correct temperature (around 0°F or -18°C). If the freezer is too warm, the ice cream maker may not freeze the mixture properly. Mixture consistency: Make sure that the mixture you are using is not too thick. If the mixture is too thick, the ice cream maker may struggle to turn the mixture and freeze it properly. Overfilling: Make sure that you are not overfilling the ice cream maker. Overfilling can cause the mixture to overflow and prevent the machine from freezing the mixture properly. Motor issue: If none of the above solutions work, there may be an issue with the motor of the ice cream maker. In this case, you may need to contact the manufacturer or a professional repair service to diagnose and fix the problem. As for turning on the furnace and power in your Hitchhiker II trailer, you may need to refer to the owner's manual or contact the manufacturer for specific instructions, as the process may vary depending on the model and year of your trailer.
2/24/2023 9:22:15 PM • Ice Cream Makers • Answered on Feb 24, 2023
How can I replace the fuse 16A 250V in my Buffalo Icecream maker ?
I have no idea. Are you an electrical engineer ..............
10/22/2022 7:19:14 AM • Ice Cream Makers • Answered on Oct 22, 2022
Anyone to help me with manual for Beiqi ice cream machine (model BQ323PA)
It appears to be a South African machine, so this link might work better for you than me in North America. https://www.google.com/search?q=Beiqi+BQ323PA+manual ..
10/5/2022 12:30:41 AM • Ice Cream Makers • Answered on Oct 05, 2022
Is cream charger necessary for making coffee?
There is no substitute for a cream whipper when it comes to making foams, sauces, and freshly whipped cream. These sealed canisters whip up whipped cream of the highest caliber in a matter of seconds by forcing air into the cream using compressed gas. These instruments are necessary for caf?s, bakeries, restaurants, and more since they let you to make a variety of desserts, milkshakes, fresh cakes, pastries, and cream infusions. However, how can you maximize the potential of your cream whipper? Cream whippers, which are most known for creating whipped cream that maintains its shape and texture, can also keep foams, sauces, and mixes fresh by delaying the start of oxidation. What happens if the multipurpose kitchen appliances you rely on suddenly break down? Fortunately, most problems can be swiftly resolved, so knowing how they operate will help you improve their performance when the occasion demands it.
9/14/2022 6:05:38 AM • Ice Cream Makers • Answered on Sep 14, 2022
Cooks essentials 700 ml ice cream maker
limited info generic answer circuit problem -paddle connection fail--cog/gear fail -motor fail need to examine unit to narrow down problem since their many to choose from
8/1/2022 2:46:33 PM • Ice Cream Makers • Answered on Aug 01, 2022
Can anyone help me get my Taylor 150 Ice Cream machine started please?
If it was fine before stored away, then either the power is not getting to the machine, (rodent damage or corroded contacts) or there is a control fault.
7/16/2022 5:58:26 PM • Ice Cream Makers • Answered on Jul 16, 2022
Instructions and recipes for Toastmaster ice cream maker
The manual is here
Toastmaster Ice creamn maker model 6701, use and care ...
https://manualzz.com > ... > Ice cream makers Toastmaster Automatic Ice Cream Maker Use and Care Guide Recipe Book Model 6701 IMPORTANT SAFEGUARDS When using electrical appliances, basic safety .. ..
7/14/2022 7:55:41 PM • Ice Cream Makers • Answered on Jul 14, 2022
I have the presto ice cream now maker model
Did you ever get the directions? I have the booklet but can't use the ice cream maker because it is missing the lifting ring, no longer available.
8/25/2021 2:28:53 PM • Ice Cream Makers • Answered on Aug 25, 2021
I need a manual for the sevoureux ice maker
Contact Sevoureux directly to request the manual.
3/21/2021 5:18:06 PM • Ice Cream Makers • Answered on Mar 21, 2021
KitchenAid Kitchen Aid KICAOWH Ice Cream Maker Attachment Logo
6 questions posted
Top KitchenAid Ice Cream Makers Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a KitchenAid Ice Cream Maker Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Ice Cream Makers
Most Popular Question
blue liquid leaking from ice cream
  • Ice Cream Makers
