20 Most Recent Panasonic BL-C30A Network Camera Questions & Answers
2answers
Http://---------------.viewnetcam.com site requires a username
Set up a new account.
9/3/2017 1:52:30 PM • Panasonic... • Answered on Sep 03, 2017
0answers
Second bl c30a
Be the first to answer 2/8/2014 8:30:01 AM • Panasonic... • Posted on Feb 08, 2014Be the first to answer
Try to setup viewnetcam
Step 1: You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html i device arrows key scroll to nstalled.
4/2/2013 7:53:32 PM • Panasonic... • Answered on Apr 02, 2013
2answers
Cam
On ur camera page select SETUP . now look on the list at the left side , scroll down till u see advance selection , now select MULTI-CAMERA . In this page u have to key in the individual camera IP address . After all that it should work
11/25/2011 9:49:40 PM • Panasonic... • Answered on Nov 25, 2011
Warning: This server is requesting that your
you can check your domain here http://www.ip-details.com/ recently i use this and got cen percent satisfaction.i got the ip details also
2/26/2011 1:33:41 PM • Panasonic... • Answered on Feb 26, 2011
Panasonic BL -C30 netcam: unable to
Hi.
Try resetting the camera.
Some of the cameras have a small recessed button on the bottom that can be hit by using a small pointed object (such as a paperclip or pen). Other models have a flap on the side that has a reset and a restart button.
If that does not apply try disconnecting power (and removing battery) from all units connected to the system, including main control unit.
8/13/2010 12:26:56 PM • Panasonic... • Answered on Aug 13, 2010
Hi, i find a problem
Base from the description of your problem its telling us that something is blocking your camera to connect to the internet, this can be due to your routers configuration to correct this one open the port that your camera is using on your router so it can be access to the internet and register with that service. You access the router setup page and look for port forwarding then open the port number that the camera is using.
7/18/2010 6:07:58 PM • Panasonic... • Answered on Jul 18, 2010
2answers
Since last week, I cannot
Hi Friend,
Try to uninstall and reinstall the drivers of the webcam,revert back please
Regards,
Aysaam
6/13/2010 4:41:36 PM • Panasonic... • Answered on Jun 13, 2010
My Panasonic BL C131A camera
Thanks for using FixYa.
You must have reset the settings for the camera. If your wireless internet connection via a router is set to have security like WEP, you need to set up the WEP key for the router itself.
You might want to check this video tutorial on how to set up the wireless camera properly.
http://videos.mrlandlord.com/view_video.php?viewkey=04a438616ff7bdb3f743&page=1&viewtype=&category=mr
I hope this helps. Thanks and good day.
-HotRatchet
6/13/2010 4:39:26 PM • Panasonic... • Answered on Jun 13, 2010
I can not get my camera to work using a sprint
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
5/8/2010 6:59:34 PM • Panasonic... • Answered on May 08, 2010
2answers
The viewnetcam.com web is not available?
i need an AZELAS BT-160 webcam diver
2/1/2010 3:40:51 AM • Panasonic... • Answered on Feb 01, 2010
2answers
I got this BL-C30A networkcamera
1/26/2010 3:43:33 AM • Panasonic... • Answered on Jan 26, 2010
6answers
Cannot see cam on viewnetcam
I had the same problem. Even tried turning DMZ on in my router, and specified the camera IP as one in the DMZ. What helped me was using a port scanner (do a google search). I then started trying different things until I saw the port was opened. Once the port was open, I was able to access the camera from the internet, even from within my internal network. It turned out my problem was I have Vonage VOIP phone service and the Vonage router was ahead of my network router. Apparently the Vonage router wasn't allowing internet traffic to the camera. I switched positions of the routers (my wireless router is now first, and my Vonage router is plugged into the wireless router) and everything works fine now.
1/9/2010 2:57:48 AM • Panasonic... • Answered on Jan 09, 2010
My camera works fine but when looking at it from
Are you putting in the correct information with Viewnetcam? Try calling them and getting this taken care of.
12/2/2009 3:17:01 PM • Panasonic... • Answered on Dec 02, 2009
Panasonic BL-C30A Network Camera Logo
42 questions posted
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
BL Panasonic
  • BL Panasonic
Most Popular Question
warning server requesting
  • Computers & Internet
