20 Most Recent
GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY SIDE REFRIGERATOR FOR 220/240 VOLTS Special Order Questions & Answers
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
1/4/2014 8:26:29 PM •
GE 20 CFT...
Answered
on Jan 04, 2014
Ge chest freezer wiring diagram
Great question but I cannot answer it. GE makes several models of chest freezers and they are not all wired the same. My eyesight is not to good and I cannot see your freezer so I cannot answer your question. You might try our friend google and look for the make and model of your freezer with the prefix schematic.
10/2/2021 4:24:47 AM •
GE Freezers
Answered
on Oct 02, 2021
Freezer temperature swings
the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
8/11/2017 2:07:14 AM •
GE Freezers
Answered
on Aug 11, 2017
