20 Most Recent
Lux Tx500 Series Smart Temp Electronic Thermostat Unopened Questions & Answers
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/You burn wood, and smoke goes up flueway.You're not running chimney smoke through ductwork so you have a heat exchanger.What kind of heat exchanger?probably air since you're running through ductwork?How much hot air or hot water is coming off heat exchanger?How big of a space can be heated with that amount of heat?Is the exchanger located in optimal location?Considerations.One room log cabin with fireplace will not stay very warm.One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.Why?Because the BTU output of firewood is much less than electric, coal, oil, or gas.Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.Maybe your wood stove output should be measured.Don't forget a huge percentage of fire heat goes straight up flueway. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
