20 Most Recent Stiebel Eltron DHC8-2 DHC 8-2 Electric Tankless Water Heater Questions & Answers
Water is hot but when you turn the mixer water gets cold
Isn't this working as designed?
3/15/2015 7:52:04 PM • Stiebel Eltron... • Answered on Mar 15, 2015
2answers
Stiebel Eltron DHC 6-2 tankless water heater. Can I reduce the power of it?
Ideally it needs to be on a separate breaker. Surely there is more than one breaker in the apartment. The only way to fix what you have would be to change the element for one with a lower wattage but unfortunately the element is not listed as a spare part. Phone the company and tell them the problem as there may be an issue with your heater shorting out somehow. https://www.stiebel-eltron-usa.com/sites/default/files/pdf/parts-dhc.pdf Others have the same issue! https://www.google.com/search?q=Stiebel-Eltron+DHC+6-2+tripping+breaker ..
5/25/2023 1:31:02 AM • Stiebel Eltron... • Answered on May 25, 2023
Model DHC 6-2 tankless. It heats a little but then why does it shut down?
possible bad heating element
4/5/2022 6:23:20 AM • Stiebel Eltron... • Answered on Apr 05, 2022
2answers
Stiebel Eltron DHC-6. Could the 220 volt breaker be the cause for the heater to provide lukewarm water and turn off?
only getting one side of the 220 so half the heat
2/28/2022 4:37:09 AM • Stiebel Eltron... • Answered on Feb 28, 2022
My stiebel eltron has no power
Is the circuit to the heater hot?
10/29/2021 7:37:07 AM • Stiebel Eltron... • Answered on Oct 29, 2021
Where to buy online the thermal cut out for Stiebel Eltron Tankless Heater part# 162474 ??
Direct from the maker
DHC Series Spare Parts List & Diagram - Stiebel Eltron
https://www.stiebel-eltron-usa.com > files > pdf
PDF Heating system. 165889. 167769. 167770 ... Safety thermal cut out. 162474. 162474. 162474. 162474. 162474. 162474. 162474. 162474. 162474. 9. Wiring block. 1 page
8/12/2021 2:30:27 AM • Stiebel Eltron... • Answered on Aug 12, 2021
Trying to install Stiebel Eltron tempra plus 24 water is leaking out both going in and going out hoses how do I fix this
CONTACT THE SELLER , WE KNOW OF NO SOLUTION FOR YOU
4/19/2021 3:23:04 AM • Stiebel Eltron... • Answered on Apr 19, 2021
My Stiebel Eltron DHE18 is 4 years old, always worked great, and still under warranty. However the water remains ice cold and the flow indicator on the display says o.o L/min
If it is under warranty, just contact the company to diagnose and fix it. The most likely cause is a failed thermostat or element, but as the flow rate is also incorrect, it may be a control board issue. This unit only seems to be available in Australia. We are in North America :>) SERVICE-HOTLINE +49 55 31 - 70 20
DHE 18/21/24 Convenience instantaneous water heater of ...
https://www.stiebel-eltron.com > home > dhw > dhe_18...
The DHE comfort instantaneous water heater from STIEBEL ELTRON guarantees high energy efficiency. Full electronic output control with 4i technology enables ...
DHE Instantaneous 3 Phase Water Heater - STIEBEL ELTRON
https://www.stiebel-eltron.com.au > dhe-instantaneous-3...
DHE 18 AU / DHE 27 AU · Made in Germany · Precise hot water temperature up to 60°C with 4i Technology · Instant and continuous flow of hot water · Electronically ...
DHE 18 SLi 25A Convenience instantaneous water heater of ...
https://www.stiebel-eltron.in > dhe_sli_electroniccomfort
Convenience instantaneous water heater DHE 18 SLi 25A of STIEBEL ELTRON ? Product information from the manufacturer, technical data, operating ...
4/2/2021 4:46:22 PM • Stiebel Eltron... • Answered on Apr 02, 2021
The problem is that the red switch at the top of
Did you see if there is anything on YouTube sounds like a bad element
12/23/2017 7:23:52 AM • Stiebel Eltron... • Answered on Dec 23, 2017
Stiebel Eltron DHC8-2 DHC 8-2 Electric Tankless Water Heater Logo
2 questions posted
Top Stiebel Eltron Water Heaters Experts
littlewheel
ADMIN Andrew
ADMIN Andrew
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
View Most Popular
  • Stiebel Eltron Water Heaters
Most Popular Question
water hot but when turn mixer water gets
  • Water Heaters
