20 Most Recent Frigidaire 18" Built-In Dishwasher Questions & Answers
Dishwasher doesn't drain.
sounds like the pump is locked up and needs replaced. try the internet appliance parts
5/22/2014 3:39:06 AM • Frigidaire 18"... • Answered on May 22, 2014
Dishwasher washes but won't drain
sounds like the drain may be blocked by food or other items check that first
4/7/2014 6:41:15 AM • Frigidaire 18"... • Answered on Apr 07, 2014
Dishwasher not draining
It has a drain line that goes to a fitting on the garbage disposal or the sink drain if no disposal. It is held on with a hose clamp and can clog easily
4/6/2014 10:37:38 PM • Frigidaire 18"... • Answered on Apr 06, 2014
Frigidaire 18" dishwasher arm is not spinning, and dishwasher is making a very loud noise.
Hi Ellie, this is AP! I understand you are experiencing some trouble with your Frigidaire built-in dishwasher. Without knowing the exact model number I would assume there are two spray arms on this dishwasher, are both arms not moving or just one? Keep in mind that some dishwashers have two spray arms that turn at alternate times. They will never move at the same time. The changing of the arms starts at different times depending model and will continue through the end of the selected wash cycle. If you can provide the model number for the dishwasher I should be able to provide you with the instructions to remove the spray arms or you could contact the manufacture they may supply it to you also. You could also apply rinse aid to the junction between the spray arms and mount to see if it will relieve the arm to spin. If not, please reply back with the model number so I could provide a more educated response. Best Wishes,
4/3/2014 6:19:54 PM • Frigidaire 18"... • Answered on Apr 03, 2014
WHERE is the float switch on a frigidaire dishwater model # fmb330rgso
I am not aware of any float switch in this model. If this a portable dishwasher and assuming the water inlet connection is open, it is likely the water inlet solenoid could be faulty. Check this site for location of parts.
1/6/2013 9:48:09 PM • Frigidaire 18"... • Answered on Jan 06, 2013
Frigidaire dishwasher doesn't drain at end of cycle.
Question edited for clarity, spelling of maker. Question moved to category
4 Tips for a Frigidaire Dishwasher Not Draining Water
Lake Appliance Repair https://lakeappliancerepair.com > blog > frigidaire-dis... Sometimes, a Frigidaire dishwasher not draining water is due to an air gap or garbage disposal clog and not a dishwasher issue. If you have an air gap or ...
There is a 1 to 2 inches of water left after cycle ends.
iFixit https://www.ifixit.com > Answers > View > There+is+a... Sep 25, 2017 - A dishwasher filter/trap/drainage basket that is clogged with chunks of food is the leading reason water remains at the bottom of a dishwasher. 3 answers · Top answer: Hi @cadillachawk , Try running the drain hose along the floor and into a bucket (or two) and ... Does not drain the water at the end of cycle - Dishwasher 44 answers Apr 30, 2010 New Dishwasher won't drain water at end of cycle 2 answers Jul 11, 2017 More results from www.ifixit.com
Frigidaire Dishwasher Not Draining ...
Repair Clinic https://www.repairclinic.com > RepairHelp > Frigidaire... The check valve prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining.
Frigidaire Dishwasher won't drain at end of cycle
Reddit · r/appliancerepair 8 comments · 1 year ago Check drain hose for debris, kinks, and partial blockages. check float sensor. Make sure it moves freely. check chopper to see if full of debris ... Frigidaire dishwasher not draining. : r/appliancerepair - Reddit Jun 26, 2022 Frigidaire Dsiwasher not draining. Any advice please? - Reddit Aug 8, 2022 r/fixit - Frigidaire dishwasher has water sitting at the bottom at ... Feb 8, 2023 Frigidaire dishwasher not draining before dry cycle - Reddit May 25, 2023 More results from www.reddit.com
Frigidaire Dishwasher Not Draining? Here's What to Do
fredsappliance.com https://fredsappliance.com > dishwasher-repair > frigid... Jul 7, 2021 - Another common cause of a dishwasher not draining is a defective drain pump. To access the drain pump, you will need to follow the instructions ... ..
2/11/2024 10:42:10 PM • Frigidaire... • Answered on Feb 11, 2024
2answers
Not washing dishes properly. Soap
if all you have is soap residue here are some things you need to do to correct this,,,have unit been cleaned out lately..no, 12 to 16 onces of bleach on regular cycle..may have to bleach unit twice,,,
the dishwashing detergent may be old [expired],check,,overloading to many dishes,,wash water is not hot enough,,one of these is your problem,,check each and you will be ok,,and use jet dry with every wash...
1/4/2024 6:57:51 PM • Frigidaire... • Answered on Jan 04, 2024
3answers
Spots on dishes
It depends on the kind of spots.
Hard water spots are just the result of minerals that were left behind when the water evaporated.
Food spots can be the result of food that was allowed to dry before putting the dishes in the dishwasher.
In general, a water softener can be quite helpful in reducing hard water spots, and can also help the dishwasher perform better.
Note too that recent changes in the formulation of dishwashing products has been a problem for people who do not have water softeners. Government mandates have recently restricted addition of phosphates in dishwashing products in many states. Phosphates were quite beneficial to the dishwashing process.
A water softener may be your best answer.
1/4/2024 6:47:37 PM • Frigidaire... • Answered on Jan 04, 2024
I have a frigidaire fgbd2438pbbb dishwasher that runs thru the wash cycle then stops and the air dry and high temp light flash. whats wrong?
Based on the symptoms you described, it's likely that there is an issue with the heating element or thermostat in your Frigidaire dishwasher. Here are some troubleshooting steps you can try:
  1. Check the heating element: The heating element is responsible for heating the water during the wash cycle and drying the dishes at the end of the cycle. If the element is faulty, the dishwasher may stop mid-cycle and display the flashing lights you described. Use a multimeter to test the continuity of the heating element. If there is no continuity, the heating element needs to be replaced.
  2. Check the thermostat: The thermostat is a safety device that prevents the dishwasher from overheating. If the thermostat is faulty, it may shut off the heating element prematurely, causing the dishwasher to stop mid-cycle. Test the thermostat using a multimeter. If it's not functioning properly, it needs to be replaced.
  3. Check the control board: If the heating element and thermostat are functioning properly, there may be an issue with the dishwasher's control board. A faulty control board can cause various issues, including the flashing lights you described. If this is the case, you may need to replace the control board.
If you're not comfortable performing these troubleshooting steps yourself, it's best to contact a qualified technician to diagnose and repair the issue.
3/14/2023 12:49:01 PM • Frigidaire... • Answered on Mar 14, 2023
Frigidaire Model FGID2466QF2A - Middle Spray arm is hitting larger dishes and may seem a bit wobbly. How do I move to provide clearance?
They should not wobble a lot. They have to be able to spin, but should not have a lot of lateral movement. See if you can remove the spray arm and clean out all the spray jets. If some are blocked at one side it causes the arm to not spin true and flat. It spin with one side high and one side low. The other problem may be incorrect loading of dishes. https://www.frigidaireapplianceparts.com/Shop-For-Parts/a9b2d2144302/Model-FGID2466QF2A-Frigidaire-Dishwasher-Parts ..
3/11/2023 6:44:43 PM • Frigidaire... • Answered on Mar 11, 2023
2answers
Lower spray arm dislodged during wash cycle
Hello Megan Quintas, I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment... So my personal opinion... You are good once you replace your defective spray arm.. Put your model+make+spray+arm or better yet the ORIGINAL PART NUMBER to get three estimates... Good luck, happy hunting!! - Some example parts houses: Sears (priciest... but improving) appliancepartspros.com partsselect.com Water Filters Lawn Garden Appliance Parts Search Over 2 1 Million Appliance Parts PartSelect Appliance Parts and Repair Help
3/6/2023 4:20:15 AM • Frigidaire... • Answered on Mar 06, 2023
2answers
Can you tell me what model year my Frigidaire dishwasher is model FFBD2406NB7B
Cannot be answered with the information provided. Need the serial number from the manufacturer's plate, which will probably tell you the year of manufacture. Here is a link to Frigidaire: https://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=FFBD2406NB
3/1/2023 9:41:54 PM • Frigidaire... • Answered on Mar 01, 2023
Frigidaire dishwasher stops after about 40 minutes. The latch to dispense the detergent does not open and the the ER code appears.
Error Code: ER
The Problem: There is a membrane switch failure, meaning one of the keys is throwing the wrong signal. This error can also be caused by a stuck key or a key pressed for longer than one minute. The Fix: Check the keys on the control panel and the wiring between the keypad and main control board. If you cannot identify and fix the issue, replace the keypad. If the error persists, replacing the main control board should fix the issue.
3/1/2023 9:33:53 PM • Frigidaire... • Answered on Mar 01, 2023
My Frigidaire dishwasher has recently started to act up. It starts the wash cycle but doesn't finish it.
Sounds just like my Whirlpool dishwasher. If you have the documentation that came with it look through it for a "reset" method to re-calibrate the dirt sensor in the unit. If you don't have the owners manual try to "Google" an owners manual or a "technicians" manual to find a reset or a re-calibrate procedure. Mine consisted of pressing certain control buttons at the same time, after which the unit ran through a calibration cycle that took about as long as a normal wash, and it has worked great ever since.
2/12/2023 1:24:54 AM • Frigidaire... • Answered on Feb 12, 2023
2answers
Hi temp/heat dry lights flashing on a frigidaire dishwasher
Please read!! This happened to us and we paid money to have repair men come look and they didn't solve the problem. Your door latch is being caught on the bottom of your counter top. Pull your dishwasher out a half an inch and try again. It fixed our problem when we had this happen!
2/2/2023 10:14:31 PM • Frigidaire... • Answered on Feb 02, 2023
Frigidaire dishwasher sanitize cycle
A High Limit Thermostat is what it says. If the temperature goes over limit, it cuts power to the element. The temperature itself is controlled by an electronic sensor called a thermistor, or a standard 'thermostat'. Try a reset control board first. https://www.google.com/search?q=Frigidaire+dishwasher+Model+FDB1500LFC0+reset How to enter Diagnostics Mode https://www.google.com/search?q=Frigidaire+dishwasher+Model+FDB1500LFC0+run+diagnostics ..
6/15/2022 4:02:38 PM • Frigidaire... • Answered on Jun 15, 2022
Frigidaire FGID2466QF7A dishwasher touchpad non-responsive
I called Frigidaire with these codes. They said it indicates a power failure happened (during a wash cycle, I suppose) and to do a hard reset. A hard reset is turning off the breaker for 30+ minutes and then flipping the breaker back on. This kind of worked, but simultaneous to the error codes, the push/pull latch on my dishwasher got set to the closed position while the door was open, so the door would not latch. I feel that this was the initial problem that caused these codes. So in my case, I had to manually rotate the latch open with bent piece of wire, to get it into the correct position first. Then the hard reset seemed fix the error codes. I was able to start a wash. It's running now.
5/9/2022 11:12:02 PM • Frigidaire... • Answered on May 09, 2022
Frigidaire gallery dishwasher where is the circut board and what is the cost of a new one?
CALL A PLUMBER CONTROL BOARDS COST QUITE A LOT AND A NEW MACHINE WOULD BE THE WAY I WOULD ATTACK THE PROBLEM
7/18/2021 12:54:07 PM • Frigidaire... • Answered on Jul 18, 2021
Frigidaire 18" Built-In Dishwasher Logo
5 questions posted
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
dishwasher doesnt drain
  • Dishwashers
