20 Most Recent
Panasonic Toughbook T2 Notebook Questions & Answers
How do i scroll up and down on a panasonic
The verticle scroll can be done in two ways. Using the mouse to point over the scroll bar. Left click and hold the left mouse button and drag your finger up or down across the touch pad. The second way is to trace a circle around the outside of the touch pad.
I hope this information was helpful. Let me know if you need any further clarification.
I have attached a link to the panasonic manual download page for your toughbook. You can download the operating instructions booklet to see more information about your toughbook.
Brian
http://www.panasonic.com/business/toughbook/computer-support-download-manuals.asp
1/9/2011 12:43:26 AM •
Panasonic...
Answered
on Jan 09, 2011
Well i felt my laptop
The lighting tube broke - you will need to open the screen case to access and replace it.
10/18/2010 3:43:26 PM •
Panasonic...
Answered
on Oct 18, 2010
Missing system file
Yer with an external hard drive or a flash drive stick, copy the OS cd on to the drive then set the bios to boot from USB or OTHER DEVICE.
1/16/2010 4:57:11 AM •
Panasonic...
Answered
on Jan 16, 2010
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
1 Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or
10/4/2009 4:23:16 PM •
Panasonic...
Answered
on Oct 04, 2009
Power off
That is because of the invention of power saving modes, where a single touch puts it in sleep mode and a 4+ second touch turns it off.
Check the bios to see if there is an option under the power saving section. You may be able to change this function to suit you.
6/10/2009 4:51:40 PM •
Panasonic...
Answered
on Jun 10, 2009
White screen
White screen usually means the display itself (not the inverter, but the panel) has gone bad.Could go in and check the ribbon cable connection to the mainboard and see what happens.
More than likely you need to replace the panel. Sorry.
4/23/2007 1:05:08 AM •
Panasonic...
Answered
on Apr 23, 2007
Screen upside down on a panasonic CF-T8
On any Panasonic Toughbook you can rotate the screen as follows:
Hold down the "CTRL" and the "ALT" keys and while holding down
these two keys press the "UP Arrow" key and then release all
three keys. This will reset the screen so it is right side up instead
of upside down.
Good Luck and regards from:
Richard, Authorized Panasonic Canada Toughbook Dealer since 1989.
P.S. The arrow keys look like this: The up arrow is the one on the top
4/6/2018 5:40:18 PM •
Panasonic...
Answered
on Apr 06, 2018
Screen stays dark
On ALL Panasonic Toughbook Models,
if the screen stays dark I would shut-off the
Toughbook and connect an external monitor
to the VGA port (15-pin female connector),
which is usually BLUE in color.
Make sure the monitor is ON first, then
turn ON the Toughbook.
If the monitor comes on then your problem
is the backlight or possibly the inverter of the
screen.
If no image is shown on the external monitor
and the screen stays dark and you cannot
hear any startup (ie. Windows) sound, then
your video card may be defective. Very few
Toughbooks fail this way since they are
normally very very relaible but it can happen.
Good Luck
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
2/18/2016 4:50:23 AM •
Panasonic...
Answered
on Feb 18, 2016
