20 Most Recent Krups Km7000 10-Cup Grind-and-Brew Coffeemaker Black Questions & Answers
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you help?
Krups Coffee... | Answered on Jun 16, 2019
Error 12 There was no pulse from the ejection switch so possibly a switch problem or worse still some grief on the control PCB. This will also be associated with the cleaning the drawer problem. From memory the switch/es are located above the used grounds bin.
Krups Coffee... | Answered on May 07, 2019
my dear sir it looks that you had some internal leaking .due to this the water went on to the electric parts . now you need to fest dry it properly then plug it in again and make sure it doesn't leak again if not check there is two thermal fuse on the ac supply sow make sure you unplug first see that you do the same as type if this get blown again then you have to change the pcb
Krups Coffee... | Answered on Apr 08, 2019
Running it fully through the cleaning cycle step by step will normally get it gone.
Krups Coffee... | Answered on Mar 19, 2019
Did you try the Krups web site for the manual? First place I'd go.
Krups Coffee... | Answered on Mar 03, 2019
Krups Km7000 10-Cup Grind-and-Brew Coffeemaker Black Logo
3 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
user manual krups 700552 coffee maker
  • Coffee Makers & Espresso Machines
