20 Most Recent
Rio Diamond SpeedStar 64 Graphics 2000 (2 MB) Graphic Card Questions & Answers
Rio se510 stuck on Reading old; Internal memory.
The Rio SE510 is a portable media player that was released several years ago. If you are encountering an issue where the device is stuck on "Reading old; Internal memory," it may indicate a problem with the device's firmware or software. Some possible solutions include:
- Reset the device: If your Rio SE510 is not responding, you can try resetting it by removing the battery and waiting for a few minutes before reinserting it.
- Update the firmware: If the issue is related to the device's firmware, you can try updating it to the latest version. You can usually download firmware updates from the manufacturer's website.
- Format the device: If the issue persists, you can try formatting the internal memory of the Rio SE510. This will erase all of the data on the device, so make sure to backup any important files before proceeding.
- Contact customer support: If none of the above solutions work, you may need to contact the manufacturer for further assistance.
Note: Keep in mind that the Rio SE510 is an older device and may not be supported by the manufacturer anymore. Additionally, the above solutions may not work if the device has hardware issues.
Bios update
Hi.
Be aware that you should only Update your BIOS when it is only your last resource, that means when you are having problems with your BIOS, because if the BIOS get corrupted you wont be able to fix it and your computer may become unusable.
If after reading this you still want to update it, all you have to do is visit the motherboard manufacturer website and look for an updated version of your BIOS, there you will find everything you need to know.
If you need to know anything else just ask, i'll help you with pleasure.
Good luck.
I have a crane 181 with a nayax reader. It's only flagging 11 MDB codes. Any answer as to why? Firmware has been up
Without more information, it's challenging to determine the exact reason why your crane 181 with a Nayax reader is only flagging 11 MDB codes. However, here are a few potential reasons why you may be experiencing this issue:
- Compatibility: Not all vending machines and readers are compatible with each other. Make sure that your Nayax reader is compatible with the Crane 181 vending machine.
- Reader configuration: Check the configuration settings of your Nayax reader to ensure that it is set up correctly for the Crane 181 vending machine.
- Communication issues: Check the communication between the Nayax reader and the vending machine. If the communication is interrupted, it may not flag all the MDB codes.
- Faulty Reader: Your Nayax reader may be faulty or damaged. In this case, you may need to replace the reader or have it repaired.
- Firmware: Even if your firmware has been updated, there may still be compatibility issues between the Nayax reader and the Crane 181 vending machine. Double-check the compatibility of your firmware with both devices.
It's best to contact the manufacturer of your Crane 181 vending machine and Nayax reader to get specific support for your issue.
