20 Most Recent
Sony CLIE PEG-TH55 Handheld Questions & Answers
Multimedia system error
You can perform full reset after backup your data. Full reset or Hard reset can be done by holding reset and power button together and releasing it after 10 seconds. It will come up with confirmation to erase all data to set it to factory default. Once you choose "Yes" it will be out of box state. It might fix the issue. For Memory card data loss you can use your PC to retrieve back by using application such as Active Undelete which can be found at
www.active-undelete.com
Good Luck
1/20/2010 7:50:03 PM •
Sony CLIE...
Answered
on Jan 20, 2010
Sony Clie PEG-TH55
There are very limited original resources to get parts for obselete products. However you can check ebay.com time to time as frequently many sellers selling Sony Clie Parts.
8/2/2009 4:35:33 PM •
Sony CLIE...
Answered
on Aug 02, 2009
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
