? 5:51www.youtube.com/watch?v=oBihToN6dxsSep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
The F3E2 Error Code indicates that there may be an issue with the Temperature Control sensor. Try resetting the washer/dryer by unplugging it from the outlet for at least 1 minute, and then plugging it back in.Another issue is a blockage in the outlet drain pipe or pump.
The low humming sound is indicative that the start / run capacitor has failed. It give the motor an electrical jolt to get it going. Call for service and tell them the story.
Your washing machine top lord or front lord? If your washing machine top load you have cleared drain valves in have blocked then check drain motor like that as you can check which model or type
please power cycle your washer (ie restart via power outlet unplug and re-plug). After this, please rotate the dial 90 degrees counter-clockwise before attempting another wash . All of these actions to help reset/undo any issues with the washer. Otherwise, you might need to schedule a home diagnosis/repair.
Thank you.
Please double check that you're accounting for the weight of the clothes in the washer. Lighter clothes should produce a lower sound and heavier loads should be much louder. If possible, you can add some oil around the rotating portion of the machine in order to lower friction.
Thank you.
Question edited for *Admiral.
Question moved from Speed to Admiral Washing Machine Category.
First check the strainers on the hose inlets to the machine. However it is likely to be the Water Inlet Solenoid.
Replacement videos
https://www.google.com/search?q=Admiral+Mega-22+water+inlet+solenoid+valve
