20 Most Recent Stoves Belling Gas Cooker Spark Ingniter Unit C00241367 Questions & Answers
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator testing before buying may save heaps of cash
5/20/2015 12:53:28 AM • Stoves... • Answered on May 20, 2015
0answers
We have a Stoves dishwasher 450DW showing falt E4
I had the same problem and emptied all the water from inside the main compartment of the dishwasher but it still showed the fault. After reading some stuff I took the dishwasher out and removed the side panel. At the very bottom of the machine was a big pool of water.
I think that when it is overfilled or the drain becomes blocked, there is an overflow that dumps some water into the base of the machine triggering a switch and shutting it down.
I cleared all the water out from the base pan and then put it all back together and that has cleared the fault and we are up and running again with clean dishes.
No need for an engineer to come out this time!!!
12/22/2009 12:14:24 PM • Stoves... • Answered on Dec 22, 2009
Dishwasher does not pump water out at the end of
First check that there isn't anything blocking the drain area inside the bottom of the dishwasher. Sometimes plastic wrap, a small Tupperware, etc. top gets sucked against the drain and blocks discharge. If nothing is there, (look really good, by getting out as much water as possible!!!). If nothing there, see if you have an "air-break" installed at the kitchen sink, this prevents backflow from the sink drain back into the dishwasher, check it by removing the decorative cover and see if it is clean and has no obstructions blocking water flow.
Another thing to check, is if you recently had a new disposal installed, it's possible that the dishwasher inlet was never "punched out" to allow for the dishwasher to drain thru the disposal. If none of those, continue with the investigation!
Check to see if some broken glass might have worked its' way into the drain area, beneath the drain discharge guard. You'll have to remove the cover, some are just clipped in place while others have a screw holding them in place.
If still nothing, it is possible that something has worked its' way all the way into the discharge pump section and you'll need to remove the dishwasher from under the counter to get at the pump section.
Normally when the dishwasher is in the pump out sequence, you can hear the pump motor and impeller spinning, if you can't, then proceed with removing the dishwasher and disconnect the power or shut off the breaker to it. It is quite possible that something has jammed the discharge impeller and is preventing pump out. Again, if you can hear the motor and impeller running, it could still have an obstruction. Bucket and towels will be needed to soak up all any water that you couldn't remove before pulling the dishwasher out from under the countertop.
If there is no obstruction in the discharge pump section and the discharge value (usually a simple rubber flap) is moving freely, then it could be the pump out solinoid (an electronic valve that opens the discharge port for pumping out water when the dishwasher is done washing and is signaled to drain. You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working OK. You'll need to reconnect the power, water inlet and discharge (drain) lines first to check this option.
7/28/2009 6:28:03 PM • Stoves... • Answered on Jul 28, 2009
How to reset a omega dishwasher dw501wa
my omega starts can hear the water then just switches of what can i do
4/22/2024 12:41:59 AM • Dishwashers • Answered Yesterday
DIO3T131FEUK Integrated dishwasher has power but won't switch on
Check Power Supply: First, ensure that the dishwasher is properly plugged into an outlet. Sometimes vibrations or nearby appliances can cause it to come unplugged. If it's plugged in, test the outlet by connecting a small appliance (like a toaster or blender) to see if it turns on. If it does, move on to the next step. Check Circuit Breaker: Verify if a circuit breaker has tripped. Go to your circuit breaker box and look for any tripped breakers. If you find one, flip it to the "off" position and then back to the "on" position. Test the dishwasher again to see if it powers on. Child Lock or Delayed Start: Some dishwashers have a child-lock feature that prevents accidental starts or changes to the wash cycle. Check your owner's manual for instructions on disabling the child lock or delayed-start features. Ensure that the dishwasher door is securely latched. Reset the Dishwasher: If the dishwasher has power but won't start, it might be stuck between cycles. Allow any drain cycle to run (if applicable), wait for 60 to 90 seconds, and then press the start button once. Unplug the dishwasher for a minute or two, then plug it back in. This can help reset the machine. Refer to the owner's manual for any specific reset procedures. If none of these steps resolve the issue, consider reaching out to professional repair services or the manufacturer for further assistance.
4/21/2024 2:44:15 PM • Dishwashers • Answered Yesterday
Karcher Puzzi 100 Spray pressure low
troubleshoot the issue: Spray Nozzle Blockage: Ensure that the spray nozzle is clear and not blocked. Sometimes debris or buildup can obstruct the nozzle, affecting the spray performance. Pump Coil and Circuit Board: The pump coil could be damaged or broken. If it's faulty, the pump won't spray at all. You can check continuity through the coil and verify that the switch is supplying power to the circuit board and, in turn, to the pump. Dry solder joints or a failed smoothing capacitor on the circuit board can also cause issues. Pumps are relatively simple solenoid plunger types, and replacements are available for around £40-£50. If you're not comfortable testing at mains voltages, seek professional assistance. Calcium Buildup and Blockages: Some pumps can be dismantled, allowing you to remove any calcium buildup or blockages. Gently tapping or shaking the pump might get it going. Recirculating a descaler can also help clear buildup without disassembly. Pump Replacement: If the pump is indeed faulty, consider replacing it with a new one. It's advisable to change the circuit board (PCB) as well. If you're unsure about electrical testing, consult an expert. Remember to follow safety precautions when dealing with electrical components. If you're not experienced, seek professional help to avoid any risks. Good luck with resolving the issue! For reference, the Karcher Puzzi 100 is designed for gentle and effective cleaning of small to medium surfaces, especially carpets and upholstery2. Its spray pressure is around 1 bar, and the spray rate is approximately 0.26 gallons per minute. If you need further assistance, consider referring to the Karcher Puzzi 100 user manual.
4/20/2024 10:55:08 PM • Dishwashers • Answered 2 days ago
Can't get dishwasher out from underneath the counter
Question edited to move it from Computers to Dishwashers. Is there by any chance a floor tile 4" out from the dishwasher front? If so, try lifting the front with a crowbar or long screwdriver. Did you disconnect, inlet hose, drain and power? They may have been installed tight, or clipped. ..
4/19/2024 6:24:59 PM • Dishwashers • Answered 3 days ago
HOW TO REPAIR A HOLE IN MY DISHWASHER
It depends upon the material you are trying to repair but Araldite or any good quality two part epoxy will suffice to fill the hole. Ensure the area is dry and clean then build up the repair . Larger holes will require multi additions of epoxy.
4/15/2024 10:01:23 PM • Dishwashers • Answered on Apr 15, 2024
2answers
I have an olle dishwasher, model DW9227C. I need to find a parts list as the lower spray arm is broken. I can't find any info on Olle appliances anywhere
Put in olle dishwasher parts and where you live . This should come up with shops that do the spares
4/9/2024 3:38:50 AM • Dishwashers • Answered on Apr 09, 2024
Elettrobar E35H glasswasher. I need a wiring diagram for it please?
Question edited for clarity. Question moved from Cars and Trucks category. This appears to be a Dutch Maker, we are in North America. There is some help here, but I don't see the wiring for that model, although there is a parts manual. The link may work better for where you live. https://www.google.com/search?q=elettrobar+e35h+wiring+diagram+pdf ..
4/6/2024 11:00:01 PM • Dishwashers • Answered on Apr 06, 2024
WINTERHALTER MODEL MTR3 GIVE ME ERROR 22.2 AND ERROR 12.1
These error messages both point to a sensor problem. Error 12.1 This error is related to the boiler temperature sensor. Consider the following: Look for a short circuit in the sensor. Inspect the cables and plugs for any issues. Ensure the sensor is correctly connected.If needed, replace the boiler temperature sensor. Error 22.2: This error pertains to the tank temperature sensor. Possible causes include: Short circuit in the sensor. Cable failure or plug failure. Sensor not properly connected. You may need to check the sensor wiring, connections, and replace the temperature sensor if necessary.
4/3/2024 6:11:13 PM • Dishwashers • Answered on Apr 03, 2024
2answers
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
3/12/2024 6:43:46 PM • Dishwashers • Answered on Mar 12, 2024
Stoves Belling Gas Cooker Spark Ingniter Unit C00241367 Logo
12 questions posted
Top Stoves Dishwashers Experts
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Stoves Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Stoves Dishwashers
  • Stoves Dishwashers
Most Popular Question
stoves plc actually think
  • Dishwashers
