20 Most Recent Neff U1863 Double circotherm super Stainless Steel Electric Oven Questions & Answers
How do I get a manual
Your manual is here at link below. NEFF U1863N2GB MANUAL Pdf Download: http://www.manualslib.com/manual/347516/Neff-U1863n2gb.html
7/9/2014 11:20:52 PM • Neff U1863... • Answered on Jul 09, 2014
What is the wire conection sequence
If there is no earth wire to the element, then it it does not matter which wire goes on the terminals of the heater, as they are common, so,as long as you do not connect the wires to earth, it will be o/k.
If one wire is green/yellow, then that goes to rearth.
Hope this helps.
12/22/2009 10:29:52 PM • Neff U1863... • Answered on Dec 22, 2009
The element has been replaced but when the
who in hades left the mains on?! do they have any brain cells between their ears!!? if it's 220-240 (if you're in Europe, prob. 220-240) a wonder you don't have a smoking corpse in your kitchen! us yanks use 220-240v for dryers and stoves, but have 2 120-110v breakers, usually, to shut off 220-240v appliances. sometimes 2 110-120v breakers locked together, so they are both shut off at the same time! seems as if something was connected incorrectly- and fried your fan and light! may need to replace fan & light, and, possibly wiring! unplug the dam thing first!!
good luck!!
10/19/2009 11:05:08 AM • Neff U1863... • Answered on Oct 19, 2009
Neff U1422 oven grill tripping RCD
The grill element has an internal short and needs replacing. Sometimes you can see it as a slight bulging of the element. This happens just before it blows a hole. It may also have been physically damaged when something was put in there after a few Sherries. :>D Sounds like your RCD is adequately sensitive.
1/2/2024 7:05:55 PM • Neff Ovens • Answered on Jan 02, 2024
Problems with touch keys on Neff B2ACH7HH0B Oven
See Troubleshooting section of manual on page 25. It may help untitled (neff-international.com)
11/8/2023 12:11:05 PM • Neff Ovens • Answered on Nov 08, 2023
Removing Oven element on a NEFF 1031-SP oven ( E-Nr B1120F1GB/01)
Check out this video on replaceing a element on a Neff. https://www.youtube.com/watch?v=YXMBwx3X74E Best to you.
8/26/2023 10:39:57 AM • Neff Ovens • Answered on Aug 26, 2023
Neff Steam Oven error code E5123.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiwgLHn8vL-AhURAzQIHRE9BqIQFnoECBsQAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft29925510-neff_steam_over_error_code_e5123&usg=AOvVaw1yI-sjEM1vvRntCUJzF6u2
5/13/2023 6:13:47 PM • Neff Ovens • Answered on May 13, 2023
Neff T18FD36X0/01 display flickering,not staying on.
If the display on your Neff T18FD36X0/01 appliance is flickering and not staying on, there could be a problem with the control board or the display module itself. Here are some steps you can take to troubleshoot the issue:
  1. Check the power supply: Make sure that the appliance is getting power by checking the outlet and the power cord. You can also try plugging in another appliance to see if the outlet is working properly.
  2. Check the control board: If the power supply is fine, the next step is to check the control board. Turn off the power to the appliance and remove the control panel cover to access the control board. Look for any loose wires, damaged connectors or burnt components. If you find any issues, you may need to replace the control board.
  3. Check the display module: If the control board is fine, the issue may be with the display module itself. Remove the control panel cover and locate the display module. Check the connections and make sure they are secure. If the connections are fine, the display module may need to be replaced.
  4. Call a professional: If you are not comfortable troubleshooting or repairing the appliance yourself, it is best to call a professional technician. They will be able to diagnose the issue and recommend the best course of action.
Remember to always turn off the power to the appliance before attempting any repairs or troubleshooting. Safety should be your top priority.
2/26/2023 2:10:59 PM • Neff Ovens • Answered on Feb 26, 2023
I can't remove the light bulb cover of my neff oven to change the bulb
A length of wood such as a dowel can be used with a mallet or small hammer. Place one end of the wood against the lamp cover so as to force it anti clockwise. Tap the other end gently.
1/21/2023 1:09:13 PM • Neff Ovens • Answered on Jan 21, 2023
My neff ovens fan is coming on but the oven is overheating
Check/replace the thermostat.
2/28/2022 12:54:15 PM • Neff Ovens • Answered on Feb 28, 2022
Cause of Neff Induction Hob Error d4?
I can only confirm that the is no D4 Error shown anywhere. If Neff, the maker can't tell you what the error is, then surely no-one can. Very poor show. I think I would be cutting my losses and go back to a traditional cooktop from a different maker and pursue a legal case against Neff. They should change their name to 'Naff'. NEFF appliances are among the most durable and reliable kitchen devices on the UK market. But every once in a while, a NEFF appliance will throw an error code for you to deal with. When a fault code is displayed on your NEFF appliance, it indicates a problem, but not what that problem is or what has caused it. An appliance fault code simply detects and indicates the nature of the issue and provides the general area where investigations need to be carried out. Bear in mind that on many occasions, your NEFF appliance will be in need of professional repair from a certified electrician to get guaranteed results. So, if :
  • You have a problem with your NEFF appliance
  • You want to know what a specific error code means
  • You want to trace and correct faults in your NEFF appliance
Then, read on. NEFF appliances fault codes and their importance Your NEFF appliance will indicate an error code if it has a problem. This will be shown on the digital display and will be a single letter followed by one or two numbers. You can use this appliance error code to help identify where the problem is occurring. The most common appliance fault codes are related to defective oven elements, drainage issues on washing machines, and blocked pumps in dishwashers. A detailed look at NEFF appliance error codes
NEFF induction hob error codes The most common faults of a NEFF induction hob are:
  • The hob not starting up;
  • The hob shutting off during cooking;
  • The hob flashing after finishing cooking;
  • The hob making a noise;
  • Food isn't cooking evenly.
NEFF induction hob error codes that may help you locate the source of the problem are shown here:
  • F1 - Tnsuitable cookware is being used, or there's no cookware in the zone;
  • F2/F02/F4/F04- Tour appliance hasn't cooled down completely;
  • F8/F08 - If your hob has been working on high power for a long time, the timeout will activate;
  • E9 - There's an internal fault with your appliance electronics.
Bear in mind that most of the issues will require a certifed induction hob engineer to complete the job and fix your NEFF appliance.
2/3/2022 5:01:09 PM • Neff Ovens • Answered on Feb 03, 2022
Neff B1820W0GB/03 oven door disassembly
The inner door glass is usually lifted out by removing the two plastic/metal clips at the top of the glass, in the corners. The glass cannot be glued in. How are you going to clean it if you do ...
1/27/2022 7:24:41 AM • Neff Ovens • Answered on Jan 27, 2022
Neff U1863 Double circotherm super Stainless Steel Electric Oven Logo
Popular Tags
9 questions posted
Top Neff Ovens Experts
Paul Carew
xxxxxx xxx
john h
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
get manual
  • Ovens
