20 Most Recent Amana NTW4501XQ Top Load Washer Questions & Answers
Load cycle completes, clothes are spun out, but washer won't agitate during wash or rinse cycles. It seems to try to agitate, a whirring noise at the beginning, but no other noise during cycle.
I would suggest checking ur cam dogs or coupler in the agitator, also the drive block and agitator spline and spindle as well. see pics load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-0.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-2.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-5.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-9.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-14.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-20.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-27.jpg load-cycle-completes-clothes-spun-out-nmtrxuhfc1nopxoeyhsrubgi-2-35.jpg
6/11/2015 10:00:01 PM • Amana NTW4501XQ... • Answered on Jun 11, 2015
Why is my Amana washer not spinning?
No spin, or lite spin try these: Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically. Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand. Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN
4/20/2015 9:56:35 PM • Amana NTW4501XQ... • Answered on Apr 20, 2015
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
8/30/2014 10:59:18 PM • Amana NTW4501XQ... • Answered on Aug 30, 2014
Amana washing machine lid is locked and it's like it's not getting power
If your Amana washing machine lid is locked and it seems like it's not getting power, there are several steps you can take to troubleshoot the issue. Follow these steps to identify and potentially resolve the problem:
3/7/2024 7:01:50 AM • Amana Washing... • Answered on Mar 07, 2024
Will an Amana washing machine, power up without the inlet valve hooked up
Probably but not advised.
3/6/2024 8:35:39 AM • Amana Washing... • Answered on Mar 06, 2024
Amana washer. Why is it acting up?
Question edited for clarity, 'Amanda' to 'Amana'. Question moved to maker category. It is sensing, and that you have something that needs a 'Delicate' setting, or a 'Woollens' setting. It provides water and very little agitation that might damage or stretch the clothes. Read the manual. Google Amana (model) manual ..
10/20/2023 4:58:36 PM • Amana Washing... • Answered on Oct 20, 2023
How can I clean my Drain filter on an Amana front load washer, model NFW5800HW3. There is no opening at the bottom of the washer. It's a full sized front panel.
The pump and filter appear to be hidden behind the front kick stripClick the arrow button to the right and go to 'Water System Parts'. The pump and filter are shown.https://www.searspartsdirect.com/model/4e6ciymtfs-001268/amana-nfw5800hw3-washer-partshttps://producthelp.amanacanada.ca/Laundry/Washers/Product_Info/Washer_Cleaning_and_Care/Cleaning_the_Pump_Filter_-_Front_Load_Washerhttps://www.google.com/search?q=Amana+front+load+washer%2C+NFW5800HW3+drain+filter..
10/3/2023 9:43:11 PM • Amana Washing... • Answered on Oct 03, 2023
I have an Amana Tandem 7300 Front Load Washing Machine.
Fiona, could it be that your'e using Liquid color-safe bleach as it is thicker than chlorine bleach and will not dispense properly from the chlorine bleach dispenser? And did you Remove the inserts from the drawer. The inserts are the detergent selector and covers of the softener and bleach dispenser.. and clean and replace them? Tis really hard not being there and being able to see the unit. But thought I'd give you these suggestions. Best to you.
8/15/2023 5:33:37 PM • Amana Washing... • Answered on Aug 15, 2023
Amana washer not draining properly
Washer will not drain: The drain water pump is the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure to check the pump to be sure a small object like clothing or similar has not lodged itself inside of it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Read more:  HYPERLINK "http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/" \l "ixzz3X2LbXMWJ" http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ The washing machine drain hose is where the water flows through to get the water out. If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the water from the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it The water pump belt (to drain out the water) may have broke or become frayed or loose. If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing the NO DRAIN issue and remove and replace if needed. If the lid switch is not working as required it will cause your washer to not drain (and many other problems). This may be unlikely as a bad lid switch will usually cause your washer to also not agitate or spin. However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity My advice is free cuz God is good! washer-fills-and-drains-at-same-time-undefined-undefined-0_1.jpg water pump clogged washer 2-undefined-undefined-1.jpg water pump hose washer clogged washer hose1-undefined-undefined-2_2.jpg water pump sump dirty-undefined-undefined-3.jpg water pump2-undefined-undefined-4_1.jpg water pump good washingmachinepumps-undefined-undefined-5_0.jpg
7/22/2023 8:01:54 PM • Amana Washing... • Answered on Jul 22, 2023
Amana washer won't continuously fill the basin with water.
Laundry Washer or Dishwasher? If it is a dishwasher, it sounds like the Flood Sensor is stopping the cycle. There is a tray between the floor and the underside of the basin. If it is a Dishwasher, you just need to find the leak and fix it. For a Laundry washer, it is a problem with the control board and needs professional diagnosis and repair.
4/7/2023 6:34:51 PM • Amana Washing... • Answered on Apr 07, 2023
Amana washer will fill with water but then will make a constant clicking noise.
Culd you please give us a Model Number.
2/27/2023 11:20:11 PM • Amana Washing... • Answered on Feb 27, 2023
Amana lwa40aw noise during spin cycle
It's possible that the loud and fast clicking noise is being caused by the driven wheel skipping, which could indicate a problem with the transmission or clutch assembly. The motor speed at spin cycle initiation could also be related to these components. One possibility is that the clutch is worn and not engaging properly, which could cause the driven wheel to skip and make a clicking noise. Another possibility is that the transmission is worn or damaged, which could also cause these symptoms. It's also possible that the motor speed control is malfunctioning, which could cause the motor to run at an incorrect speed during the spin cycle. This could contribute to the belt wear issue you experienced. I would recommend contacting a professional appliance repair technician to diagnose and repair the issue, as it may require disassembly of the machine and specialized tools to properly diagnose and fix.
2/26/2023 5:14:36 AM • Amana Washing... • Answered on Feb 26, 2023
What is the capacity of top load amana ntw4516fw
3.5 cubic ft. here is a link to manual copy and paste https://www.manua.ls/amana/ntw4516fw/manual ..
2/22/2023 3:04:45 PM • Amana Washing... • Answered on Feb 22, 2023
My Amana works fine. Then when it gets to rinse it won't advance and the rinse just keeps blinking
It sounds like there may be an issue with the remote control you are using for your Polaroid TV. If the remote is able to turn the TV on and off, but cannot change channels or scan for antenna channels, it may be a problem with the remote's programming or compatibility with the TV. One solution to try is to reprogram the remote to work with the TV. The instructions for doing this can usually be found in the user manual for the remote or on the manufacturer's website. If that doesn't work, you can also try using a different remote control to see if that resolves the issue. If the problem persists, it may be a problem with the TV itself and you may need to contact the manufacturer for further assistance.
1/17/2023 7:14:19 PM • Amana Washing... • Answered on Jan 17, 2023
Amana Washing Machine Fault Code Help?
It sounds like an inlet water valve issue due to the humming. The solenoid isn't opening the valve fully and that makes them hum.
1/15/2023 10:58:03 PM • Amana Washing... • Answered on Jan 15, 2023
2answers
How do I bypass the lid lock on my amana washer? It is a top loader.
Don't buy any appliances that are engineered to fail.maybe manufacturers will begin to value customers more than profit.HAHAHAHAaaa,,, almost hurt myself,,that's funny
12/23/2022 11:51:17 PM • Amana Washing... • Answered on Dec 23, 2022
Amana NTW4501XQ Top Load Washer Logo
4 questions posted
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Washing Machines
Most Popular Question
load cycle completes clothes spun out
  • Washing Machines
