20 Most Recent Sony VAIO FRV37 Notebook Questions & Answers
I have a Sony FRV 35 Laptop.
you can wire them together. just splice the wires on the one that runs weird add wire to it and run those wires into the one that runs good. fans-pqfunuwknw4vp4n11tz3d5td-2-0.jpg I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
6/6/2017 3:39:10 AM • Sony VAIO FRV37... • Answered on Jun 06, 2017
Sony VAIO 8Z1L
What is the problem?
4/9/2012 3:43:43 AM • Sony VAIO FRV37... • Answered on Apr 09, 2012
My laptop model pcgfr55e I dont know if it can
I don't believe your computer has wireless capability. If not, you can purchase a PCMCIA wireless card that would work.
10/25/2011 7:47:06 PM • Sony VAIO FRV37... • Answered on Oct 25, 2011
It's not a notebook.
Possibly there might be a problem with the Video Card in the All in One PC.
You can try updating the BIOS version and the Video Card driver to correct the issue. If this won't fix the problem, contact your computer manufacturer for further help with a possible hardware problem.
8/7/2011 6:49:39 PM • Sony VAIO FRV37... • Answered on Aug 07, 2011
ON STARTUP I GET VAIO INTRO AND SOUND THEN IT
Hi
if this is a new or recent problem you could try a system restore back to when you think it was
running ok
And have you recently installed any updates that may of cause this to happen
if the restore dont fix the problem please come back to us telling us exactly what happens
and when also what operating system are you using eg xp vista or windows 7
many thanks
3/6/2011 10:44:00 AM • Sony VAIO FRV37... • Answered on Mar 06, 2011
Machine idetifies the cd drive but it will not
1. Make sure you have the most current driver installed (from the Sony website).
2. Try to play once the new driver is installed.
If it still doesn't play, your CD drive is dead :( sorry.
--Crazy PC Lady
12/24/2010 11:59:53 PM • Sony VAIO FRV37... • Answered on Dec 24, 2010
2answers
How can I speed up
Hey
If you only have 512MB of ram, installing more ram will speed it up a lot. Max supported ram is 1024 or 1GB. install another 512MB ram module.
it will improve the performance.
Do not install windows 7 to this computer, it does not have enough ram it will be slower.
Let me know if you need further assistance or advice. Ekse
11/22/2010 4:04:56 PM • Sony VAIO FRV37... • Answered on Nov 22, 2010
When i open my vaio pcg-frv37 laptop it says NTDLR
  1. Insert the Windows XP installation CD into your computers CD-ROM drive and restart.
  2. You will be prompted to “Press any key to boot from CD…”. Press a key.
  3. Once loaded, the Windows XP setup menu will give you several options. Press the “R” key to repair Windows.
  4. When prompted, selected your Windows installation. In most cases this is “1′. Press enter.
  5. You will then be prompted for your administrator password, enter that password. If you don’t have a password set, just press enter.
  6. Type the following commands, pressing enter after each line. Replace “e:\” with the letter of your CD-ROM drive.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
    fixboot
    fixmbr
    bootcfg /rebuild
  7. After entering that last line and pressing enter, you will be walked through the process of rebuilding the boot file. Most of the prompts should be self explanatory, but here are a few tips:
    • The first prompt should ask you to confirm the operating system that was automatically detected. Make sure the detected OS is the operating system you have installed and then type “y” and press enter.
    • You will also be prompted for a “load identifier”. This is the user friendly name that is displayed when selecting advanced startup options. You can type anything you want here, but it is best to type the full name of the operating system (such as “Windows XP Home Edition).
  8. Eject the CD from your computer. Type “exit” and press enter. Your computer will restart, and this time it should load without displaying an error.
6/5/2010 2:54:52 AM • Sony VAIO FRV37... • Answered on Jun 05, 2010
NORTON GO BACK HAS CONTROL OVER MY COMPUTER
JUST UNINSTALL IT FROM
CONTROL PANEL>ADD REMOVE PROGRAMS or vista/7 control panel>programs and features
4/11/2010 1:25:44 AM • Sony VAIO FRV37... • Answered on Apr 11, 2010
2answers
My problem is, i've had this computer for since
it have 2 reason
first u check to change another memory
last ur fans in ur cpu not work fine so can not heat relieving for ur cpu so when overheat it auto turn off
3/13/2010 3:58:01 PM • Sony VAIO FRV37... • Answered on Mar 13, 2010
Memory Problems FRV37
if it appears a blue screen,, your computer have a problem with the memory..
you can use two memory in two slots if it is the speed of the memory and slot has the same value..
if doesn't ,, you must back the one and buy one that the same to the normal memory..
10/23/2009 4:30:59 PM • Sony VAIO FRV37... • Answered on Oct 23, 2009
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
10/16/2009 7:18:50 PM • Sony VAIO FRV37... • Answered on Oct 16, 2009
2answers
Sony pcg frv 37
Well there are some things that might help you with this...
  1. first you need to figyer out weather you have a Hardware, or Software problem.
Here are some ideas...
  • Go to http://www.iobit.com/advancedwindowscareper.html?Str=download for a free scanner. I use it all the time!  When you download it and install it, open it and let it scan... this will find ANY problems on your computer!!!
  • if this dosn't help then go to http://free.grisoft.com/ww.download-avg-anti-virus-free-edition#tba2 and download the AVG Free.  when it is done installing let it scan your computer (may take about 1-2 hrs)
  • if this does not help and you have no warranty, then I would just sell it somewhere like ebay...
and get a newer one :)
10/16/2009 2:23:49 AM • Sony VAIO FRV37... • Answered on Oct 16, 2009
HI, I try to install
Your new HD needs to be formatted and partitioned.
Here is a link to a free and SAFE program that will format your new drive:
http://www.seagate.com/www/en-us/support/downloads/seatools
Once you format the HD, your recovery cd will be able to find it!!
Contact me if you need help with the SeaTools.
10/9/2009 8:13:45 PM • Sony VAIO FRV37... • Answered on Oct 09, 2009
Battery lights and fan works but nothing else does
Better check first your air vents/holes for build up clogs. Might be a thermal problem. Blow that using compressed air can. Second check your memory card, might be dirty contact with the connector. Cleaning using a soft eraser only its edge connector. But disconnect first the battery and Power Adaptor supply line and power it down completely before doing so.
Could be its problem is dirt build up. If this first steps fails, consider your plan checking its internal. For overheat and other check up.
For inputs, hope it helps.
8/30/2009 5:09:33 PM • Sony VAIO FRV37... • Answered on Aug 30, 2009
I have a Sony PCG-FRV37 ''error loading operating system''
Look at the bios and see if the hard drive is detected
if not suspect a virus , faulty hard disk or motherboard
8/27/2009 12:46:28 AM • Sony VAIO FRV37... • Answered on Aug 27, 2009
SONY VAIO FRV37 help please
clear the bios
8/2/2009 12:02:06 AM • Sony VAIO FRV37... • Answered on Aug 02, 2009
Sony VAIO FRV37 Notebook Logo
46 questions posted
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
VAIO Sony
  • VAIO Sony
Most Popular Question
memory problems frv37
  • Computers & Internet
