20 Most Recent Neff T1323 Electric Cooktop Questions & Answers
0answers
0answers
Neff t1213 hob
Be the first to answer 10/13/2013 3:00:45 AM • Neff T1323... • Posted on Oct 13, 2013Be the first to answer
0answers
Press power on switch and blows main fuse box
Possible that the main heating element is faulty. It is possible that the wires have shorted or due to insects if there was failure of the insulation of the wires leading to shorting of the lead lines.
Disconnect the main lines and use a multimeter to check and confirm the short of the heating element or wires.
Take all precaution for safety in testing live circuit.
8/18/2011 11:34:46 AM • Neff T1323... • Answered on Aug 18, 2011
I have lost the installation instructions
when cutting the worktop to fit this in make the hole 10mm smaller than the hob
8/11/2011 11:09:15 AM • Neff T1323... • Answered on Aug 11, 2011
0answers
I don't know how to
I think that I would get an electrician if it isn't a straight forward plug
6/10/2011 2:27:32 PM • Neff T1323... • Answered on Jun 10, 2011
2answers
How do you switch off the child lock on the neff
Touch on/off pad for 6 seconds til key symbol goes out.
9/5/2010 2:54:15 AM • Neff T1323... • Answered on Sep 05, 2010
I have a neff T1.D20 dual circuit hotplate but
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
10/3/2009 11:43:34 AM • Neff T1323... • Answered on Oct 03, 2009
Neff instructions
Visit http://www.bshcustomerservice.com/
And enter your model number to download a PDF instrustion manual.
6/25/2009 9:18:48 PM • Neff T1323... • Answered on Jun 25, 2009
2answers
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
6/13/2009 5:37:06 PM • Neff T1323... • Answered on Jun 13, 2009
0answers
NEFF Hob Wok Ignition Not Working.
It sounds like there may be an issue with the ignition system specifically for the wok burner. Here are a few potential causes:
  1. Faulty Ignition Head: The ignition head may not be generating enough spark to ignite the gas. Since you mentioned that a weak spark can be seen when foil is placed between the ignition head and earth, this could indicate a weak spark from the ignition head.
  2. Dirty Ignition Head: If the ignition head is dirty or covered in grime, it may not be able to generate a strong spark. You can try cleaning the ignition head with a soft brush or a toothbrush to remove any debris or buildup.
  3. Loose Connections: Check to make sure all the electrical connections for the ignition system are tight and secure. A loose connection could cause the ignition to fail.
  4. Faulty Spark Module: The spark module provides power to the ignition system. If it's faulty, the ignition may not work properly. However, since the other burners are working fine, it's less likely that the spark module is the issue.
If none of these solutions work, it may be best to call a professional to diagnose and repair the issue.
4/23/2023 7:41:41 AM • Neff Cooktops • Answered on Apr 23, 2023
Neff induction hob
And what about it we wonder .......
6/6/2021 11:50:48 AM • Neff Cooktops • Answered on Jun 06, 2021
Neff T1323 Electric Cooktop Logo
21 questions posted
Top Neff Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Neff Cooktops
  • Neff Cooktops
Most Popular Question
neff t1 d20 dual circuit hotplate but
  • Cooktops
