20 Most Recent
Sony UP DR100 Thermal Photo Printer Questions & Answers
UP-DR100 cannot install port - error message "target device cannot be found"
I have a question does the first lap top still use the usb cable?
if not:
1) the cable is crappy
2) the printers ports my have malfunctioned
If it is:
(common mistakes)
1) the second computer doesn't have drivers for the usb
- the first laptop may be running on an older service pack so it can bipass the cord.
2) you turned the computer on before the printer.
I purchased a Sony Commercial
You can buy converter from scsi to usb.
Chek below link.
Click here
Then you can use your printer with usb cable to your laptop.
Let me know if you need further assistance.
Thanks for using FixYa.
Blank paper coming out
Could paper be upside down? The rolls may be wound wrong. Thermal paper only is sensitive one side. Rolls might be defective.
It keeps saying door open and I can't find which
Kindly check all the trays , it can happen if any paper has got stuck , kindly turn the printer upside down and shake lightly do this after removing the cartridge and power cable.
Good Luck.
Won't print but says "Ready"
Hi
I have the same problem - how do I get it to print it says READY and its connected to my CPU via a SCSI card 50 pin NOW WHAT???? Do I need to install something else - do I need to use a specific program????
I have two updr 100's, they print fine by
there is a third piece you need to daisy chain the printers together. I do not remember the name off hand.
I was wondering the same thing until I read one of the "full" manuals.
the piece can be found on ebay it has been going out lately for 200-300 dollars. thats why I stopped looking for the piece 2 years ago.
Prints have a thin white line across all the
- Thermal head — generates heat; prints on paper
- Platen — a rubber roller that feeds paper
- Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
- Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
