20 Most Recent Neff 28 in. T2766 Gas Cooktop Questions & Answers
Ignition on centre burner keeps tripping, how do I
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
8/19/2010 12:22:31 AM • Neff 28 in.... • Answered on Aug 19, 2010
Automatic ignition 'clicks' and 'sparks' non-stop
switch and spark module,
1/20/2008 6:19:20 AM • Neff 28 in.... • Answered on Jan 20, 2008
NEFF Hob Wok Ignition Not Working.
It sounds like there may be an issue with the ignition system specifically for the wok burner. Here are a few potential causes:
  1. Faulty Ignition Head: The ignition head may not be generating enough spark to ignite the gas. Since you mentioned that a weak spark can be seen when foil is placed between the ignition head and earth, this could indicate a weak spark from the ignition head.
  2. Dirty Ignition Head: If the ignition head is dirty or covered in grime, it may not be able to generate a strong spark. You can try cleaning the ignition head with a soft brush or a toothbrush to remove any debris or buildup.
  3. Loose Connections: Check to make sure all the electrical connections for the ignition system are tight and secure. A loose connection could cause the ignition to fail.
  4. Faulty Spark Module: The spark module provides power to the ignition system. If it's faulty, the ignition may not work properly. However, since the other burners are working fine, it's less likely that the spark module is the issue.
If none of these solutions work, it may be best to call a professional to diagnose and repair the issue.
4/23/2023 7:41:41 AM • Neff Cooktops • Answered on Apr 23, 2023
Neff induction hob
And what about it we wonder .......
6/6/2021 11:50:48 AM • Neff Cooktops • Answered on Jun 06, 2021
My Neff induction hob shows an error code of er 22?
That means circuit board error. You will need a replacement or tech.
10/11/2018 7:08:56 PM • Neff Cooktops • Answered on Oct 11, 2018
Worktop cutout size for Neff Gas Hob T2766No/01
google make and model and down load manual from makers site
6/26/2018 7:39:25 PM • Neff Cooktops • Answered on Jun 26, 2018
I have a Neff 5 burner hob. The middle burner
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol always unplug electricity before attempting to repair on any electrical appliance .
10/2/2017 12:52:56 PM • Neff Cooktops • Answered on Oct 02, 2017
Dear sirs, we have a Neff hob T1213N0GB , is this an induction hob or a halogen hob please ?
It is listed as a ceramic hob, not induction
8/14/2016 5:40:30 PM • Neff Cooktops • Answered on Aug 14, 2016
Neff 28 in. T2766 Gas Cooktop Logo
Popular Tags
8 questions posted
Top Neff Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Neff Cooktops
  • Neff Cooktops
Most Popular Question
automatic ignition clicks sparks non
  • Cooktops
