20 Most Recent Sharp AL-1530CS All-In-One Laser Printer Questions & Answers
I have a Sharp AL-2020 All in One printer. The
To reset the drum light on your Sharp AL2020 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the "auto" key (exposure mode) then the "C" key then the "auto" key again.
So in other words C, Auto, C, Auto
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
1/3/2019 1:39:32 PM • Sharp AL-1530CS... • Answered on Jan 03, 2019
2answers
Drum replacement
simulation 24 7 will clear the drum counter
5/11/2016 8:01:25 AM • Sharp AL-1530CS... • Answered on May 11, 2016
I need a schematic or manuel to open right areas or fix.
Well to do a reset , you don't need to open anywhere but it depends on what reset. To open the scanner glass, just lift the platen cover up and you will see right and left screws , unscrew them and remove the glass and wipe inside.
1/16/2013 8:17:48 PM • Sharp AL-1530CS... • Answered on Jan 16, 2013
How do i print with color on this machine?
This machine (Sharp AL 1530CS) is a black and white printer/copier but can Scan (not print) in colour. It only has a black toner so will never print in colour...sorryhttp://www.sharp.net.au/cms/products/4011/downloads/AL1530CS_Brochure.pdf
1/2/2012 3:19:42 AM • Sharp AL-1530CS... • Answered on Jan 02, 2012
2answers
Sharp AL 1457 Flashes code L
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
WheatlandServices
1/25/2011 2:25:41 PM • Sharp AL-1530CS... • Answered on Jan 25, 2011
My sharp al-1530cs keeps flashing a L and will not
L what? These Sharp machines will flash a letter followed by a number such as L 1. The L1 is the most common so I will give you my link for that solution. If this is not correct just reply back with the code you have.
WheatlandServices
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
11/5/2010 8:03:41 PM • Sharp AL-1530CS... • Answered on Nov 05, 2010
DRIVER SHARP AL1530CS
available here for free download-
http://download.cnet.com/SHARP-AL-1530CS/3000-2116_4-70411.html
7/31/2010 4:39:42 PM • Sharp AL-1530CS... • Answered on Jul 31, 2010
0answers
We have a SHARP 1530-cs copier flashing #7 error
My AL-1530-CS printer will not copy
4/9/2010 2:09:56 AM • Sharp AL-1530CS... • Answered on Apr 09, 2010
Sharp AL-1530 copier , when copies are made the
Check for registration options in your menu.
4/6/2010 10:46:41 PM • Sharp AL-1530CS... • Answered on Apr 06, 2010
2answers
I want to install my AL-1530CS with my new HP
There are NO Win 7 drivers, and I suspect there never will be. Sharp are NOT writing a Win 7 driver, for this "Old", according to Win 7, hardware. You may be able to install a, XP SP2 or Vista 64 bit driver, and setup in Compatibility Mode, however if you do,do this EVERY-TIME you Bootup you MUST press F8, and select to Disable "Digital Signature Checking" at bottom of list. You need to do that at install time too.
3/16/2010 6:56:24 PM • Sharp AL-1530CS... • Answered on Mar 16, 2010
2answers
Sharps AL 1530CS flashing L service code
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
3/7/2010 12:36:08 AM • Sharp AL-1530CS... • Answered on Mar 07, 2010
Where is the toner supply in the al sharp 1530cs
Hi there
I only know that some where in the menu setup on your printer there is a place there to reset the count for you toner.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Sharp-AL-1530CS-AL-1540CS-AL-15-Manual.pdfhttp://www.4all2sell.com/pdf/Canon-PIXMA-MP470-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2/26/2010 12:56:05 PM • Sharp AL-1530CS... • Answered on Feb 26, 2010
I have a AL sharp 1530 cs copier, i replace the
May be it has fault, open it and insert again.
Set toner supply.
C-Photo-c-photo, press 25,press print key.
2/26/2010 5:01:36 AM • Sharp AL-1530CS... • Answered on Feb 26, 2010
Sharp AL-1530CS All-In-One Laser Printer Logo
46 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
AL Sharp
  • AL Sharp
Most Popular Question
print color machine
  • Office Equipment & Supplies
