20 Most Recent
LG Ranges LRE30453ST 30 Inch Freestanding With Convection Oven Ele Questions & Answers
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
12/5/2013 2:37:28 AM •
LG Ranges...
Answered
on Dec 05, 2013
I have an LG glass cook top stove. It is just 3
Only a couple things would cause this First if it is to tight in the opening. Next is there was a small crack on the edge somewhere and when it heated up or the slightest vibration expanded it similar to a small chip in a windshield that grows over time.This could easily happen during installation if not being very careful. And finally is a defect in the material, This is probally unlikely but possible look at the glass very carefully for flaws. If you find any see if LG will repair for free.
6/18/2010 4:03:24 PM •
LG Cooktops
Answered
on Jun 18, 2010
Jenn Air C221 element only goes to high?
Based on the symptoms described, it is possible that the issue lies with the ceramic element that the burners connect to at the back of the burner unit. This could be causing a short circuit between the two burners, which is preventing the large burner from being adjusted lower when both burners are on.
It is also possible that there is an issue with the wiring or connections between the two burners, which is causing a similar short circuit. However, given that the smaller burner appears to be working fine, this seems less likely.
Another potential cause of this issue could be a problem with the control board or another component of the stove's electrical system. However, given that replacing the infinite switch and receptacle for the large burner did not resolve the issue, it seems less likely that this is the root cause.
In order to determine the exact cause of this issue, it may be necessary to consult with a professional appliance repair technician who can diagnose and repair the stove.
6/21/2023 9:17:30 PM •
Cooktops
Answered
on Jun 21, 2023
Domain ceramic cooktop cec70 will not turn off
If your ceramic cooktop model CEC70 is not turning off, there are a few steps you can take to troubleshoot the issue:
1. Check the controls: Ensure that you have properly followed the instructions to turn off the cooktop. Some models may require you to press and hold a specific button or combination of buttons to power off the cooktop. Refer to the user manual for your specific model for detailed instructions on turning it off.
2. Power cycling: Try power cycling the cooktop by turning off the power at the circuit breaker or unplugging it from the power source. Leave it unplugged or with the power off for a few minutes before plugging it back in or turning the power back on. This can sometimes help reset the controls and resolve any temporary issues.
3. Control lock: Check if the cooktop has a control lock feature that might be activated. Some models have a lock function to prevent accidental changes to the settings. Look for a button or key combination that activates or deactivates the control lock. Refer to the user manual for instructions specific to your model.
4. Contact customer support: If the issue persists, it is recommended to reach out to the manufacturer's customer support or consult a professional technician who specializes in appliance repairs. They will be able to provide further guidance or arrange for a service visit to diagnose and fix the problem.
Remember, when dealing with electrical appliances, it's always important to prioritize safety. If you encounter any unusual or potentially hazardous situations, such as smoke, sparks, or strong odors, immediately turn off the power supply and contact a professional technician for assistance.
6/19/2023 9:27:30 AM •
Cooktops
Answered
on Jun 19, 2023
