20 Most Recent Hobart C44a Commercial Dishwasher Questions & Answers
2answers
Model number AM 14 sercial number 121027861 it will not take water
Test the inlet valve for voltage. if voltage is there, it's a bad solenoid.
10/19/2016 3:08:56 AM • Hobart C44a... • Answered on Oct 19, 2016
When powered up, why do the machine relays and water solenoids click on then go off, repeating this action a few seconds later?
this is normal. The tank water waves when wash motor is running and the float probe goes on and off
7/11/2016 10:24:51 PM • Hobart C44a... • Answered on Jul 11, 2016
Why when I ask for commercial dishwshers do I get a page of washing machins
I would say you are using a poor search engine. See Google results below: 26132415-vsyhdoshptbshstnvvnamuyf-5-0.png I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
3/17/2016 1:50:21 AM • Hobart C44a... • Answered on Mar 17, 2016
0answers
Not igniting
Be the first to answer 1/6/2016 6:10:06 PM • Hobart C44a... • Posted on Jan 06, 2016Be the first to answer
Trips breaker once in awhile.Not consistent. Replaced elements, contactors, wash motor. Still trips once in awhile.
check for a bad connection, if there is a bad connection it could draw more amperage then it should.
6/25/2015 7:32:49 PM • Hobart C44a... • Answered on Jun 25, 2015
0answers
Rinse temp not high enough on hobart c44a dishwasher
If your water temp. gauge (on piping) is showing 180 but the digital display is only reading 125 deg. then I would remove the water temp sensor from the rinse piping on back upper part of machine (It is a small probe with wires coming out of it). Clean probe with emery cloth and put it back in to see if that changes the display. If it doesn't then you may need to replace the probe.
12/9/2014 10:20:35 PM • Hobart C44a... • Answered on Dec 09, 2014
How Do I fill the dishwasher with water to first start it
Close the front access door and turn on the power switch. It should automatically fill.
12/1/2014 2:05:56 PM • Hobart C44a... • Answered on Dec 01, 2014
0answers
Wire diagram
Be the first to answer 6/19/2014 1:57:06 PM • Hobart C44a... • Posted on Jun 19, 2014Be the first to answer
Gas burner won't lite to heat wash water
Asuming the gas isn't turned off. The usual cause is a dirty or blocked air inlet to the combustion box. Fun to get at as it's behind the conveyor drive motor. When you remove the intake baffle from between the fan and it's rectangular inlet, make a note of how many holes are covered and open. You might have 8 open and 4 half open for instance. Thoroughly clean the inlet, and fan blades and housing. It's probably choked enough to run a rich mixture, which is reluctant to light. You may even have a backfire when the unburnt gas ignites in the exhaust plenum. Any further in and you should be a certified gas technician. There is an interlock switch on the burner box. If you need to go inside the box, shut off the gas. It will allow you to monitor the ignitor and hear and see the ignition arc. Process of elimination from there. Prove for good air, correct manifold pressure, ignition and flame monitor. Remote chance its the flame rod oxidised. Have new gaskets handy if you are removing the ignitor rods, and place back exactly where they were for correct gaps of igniter and flame rods.
3/23/2014 4:25:14 PM • Hobart C44a... • Answered on Mar 23, 2014
0answers
0answers
Strong gas fumes when burner is on to bring up wash temp just had burner replaced
there are only two reasons that this would happen. 1. The burners are not adjusted correctly for optimal performance and they are running rich. Could be a gas pressure issue causing this or the orifice and fuel air adjustment needs checked. 2. The ventilation is not adequate. You need to measure the CO level if this is not vented to the outside. If it is then you need to make sure the flu is adequate and there are in temp inversion issues or room air causing backflow etc.
6/6/2013 2:54:18 AM • Hobart C44a... • Answered on Jun 06, 2013
0answers
How to fix a commercial dishwasher
Simply determine what is not working, diagnose the problem, make correction or replace defective part and test operation. This is the best answer possible as there is no information as to what is wrong with the machine in your post.
2/23/2013 10:01:27 PM • Hobart C44a... • Answered on Feb 23, 2013
Hobart C44a Commercial Dishwasher Logo
26 questions posted
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Hobart Dishwashers
  • Hobart Dishwashers
Most Popular Question
model number am 14 sercial number
  • Dishwashers
