20 Most Recent
Roper RAX4233PQ Top Load Washer Questions & Answers
Whirlpool "Roper" top-loading washer leaking
two screws hold back control panel on. panel flips up. two clips hold case on. remove clips and lid switch plug and whole outer case will tilt forward off machine base. pump is down in front and can be bought separate.
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
What would cause my washer not to spin
If you don't hear a click when you close the lid, it could be the lid switch, if you hear humming but not moving, it could be the motor coupler, and if you can turn the drum by hand with lid open, it may be a bad clutch. Those are the top complaints.
How do i replace the lid switch
To get to the switch you first have to pull the control cover off. There should be two screws one on each side on the front at the edge. After you remove the cover there will be two gold colored clips that hold the top on stick a screw driver in the hole and pop the latch over until they come out. then the whole front of the machine will be loose. Now lean the front over and look through the lid and you will see two wires going from the lid switch to the main machine, disconnect the wires from the main machine and lift the cover out of the way. you now can get to the switch in the front cover. on this type machine all the lid switch does is keep the machine from spinning with the lid open. if that is the problem you are having then you can bypass the switch with a jumper wire and run it to see if that is the problem. You can if you want hook the two wires to gather and totally by pass the switch and put the machine back together. that will do away with the switches safety feature . I would not do this if you have children that might be using the machine.once you have the switch fixed set the front back on the pins on the base and lean it back over reconnect the wires and the push the clips back in place with a screw driver. hope this helps
My washer is leaking into the drum from the fill
(pre-typed to cover hot and/or cold!)
This is symptomatic of a malfunctioning (not closing completely) water control valve
With power off, if it is hot AND cold fill, turn one or the other off and see which one is causing the problem. Sorry but it needs replacing and a service call ;-0(
If it's cold fill only it's clear which one!!
If is only happens when there is power on it could be the PCB malfunctioning and will require checking by the service call.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Everything works except the dial
If what is happening is you start the cycle and the timer does not advance but if you manually advance it by turning it via the knob and it works fine as far it will agitate and drain/spin.
The problem will be the timer is defective and would need to be replaced.
GENE
Good evening, My Roper
I am thinking if all works good except won't spin, it is your lid switch. Under your washer lid you will notice a peg of some sort that when lidnis closed goes into a slot/hole and that triggers the spin cycle. That is in lamens terms know as a safety idiot switch. It is designed so when the washer is spinning at those high speeds,na child or not to smart adult does not open lid and put hand in while spinning. SO, if switch goes out, of course it won't spin. Switch is cheap , under 20 bucks at any appliance parts store, and they even can tell you at store how to putnin yourself by showing on one of there washers on display. Let me know if I nailed it!! Thanks Mike
