see the next steps and use the common sense: God bless you
Water Level Control / Pressure Switch
his is the most common reason a washer will agitate but not spin. To
check this on most , with no water you should have continuity on pins
7&15. With the tub full 7&16 should have continuity. This video
walks you thru
checking another type of switch.
Lid Switch
This can be the problem for the washer not spinning . Most whirlpool
styles this will effect both agitate and spin but some models will still
agitate but not spin.This is easy to check. You will need to remove the
switch, this varies with model type but the testing will be the same.
When the lid is closed the switch should have continuity when the lid is
opend the switch should have no continuity. If it differs
replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or
disassemble to access the motor. Check the leads from the timer to the
motor when turned to a wash cycle this should have 120 volts. If not
replace the Timer, if it does the timer is not the problem.
Motor
To
check the motor you will need to
disassemble the washer
to access the motor. First you can check the motor windings, to do this
remove the plug and connect ohmeter to terminals. Refer to the tech
sheet or service manual for the proper reading. Check motor for shorts
by connecting ohmeter to terminals and motor housing should have no
continuity. Connect voltmeter to motor wire connector and check for
voltage. You should have 120 volts, if you do and the motor does not run
replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check
for black soot from belt wear. Replace if it has excessive wear or
broke.
Motor Coupler
This is a fairly common problem with direct drive machines but
inexpensive and easy to replace. The Motor Coupler transfers power from
the motor to thetransmission. The following video will walk you through
the
replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive
remove the motor
and then turn tub inside. If it spins freely with no noise theproblem
is elsewhere. If it is noisy it needs replacing this is expensive and
depending on the age of your machine you may not want to replace it. On a
belt drive remove the belts and spin tub.
