20 Most Recent
Roper REK2950W Electric Dryer Questions & Answers
Cant figure out how dryer belt goes around pully
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Dryer runs but does not
Could be a thermal fuse on the back of the dryer. remove the back panel and with an ohm meter check all the components that have 2 wires going to them. one or two of these is the thermal fuse. Also could be the element. it is also in the back and has 2 wires going to it.
The timer may not be working on the auto dry cycle because there is no heat.
I am putting an new
normally yes the center terminal on the cord is the neutral wire and the 2 outer wires are for power,on the dryer the neutral is in the center and may have a metal strap to the units case
I have a Kenmore Model apartment dryer.
brandy you can get the filter you want from a coin opp dealer . or a appliance parts co that deals in coin opp . kenmore / roper / whirlpool / ect / use your model # . mm
I have a very old roper dryer (11 yrs), it quit
You've got an open circuit somewhere in the loop betwixt the start button, the "safety" button actuated by the door, and the motor/heat coils. Trace out those circuits and you'll have that thing running in no time.
Roper dryer will not start
Did you check where the door closes. There should be an accuatator on the door side that will depress a safety switch inside the housing. Take a flat scerw driver & push the lever in on the switch in the housing once you have set the controls to run. This could be the problem, but there could be other problems, Good luck.
Roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Roper EL5030V Electric Dryer
yes there are two, one is on the blower housing a small white on with two blue wires connected to it, the other is on the element housing at the left top it has 2 red wires connected to it
both of these if good will read contunity.
Dryer is not heating up
Frist need to check red and black for 220 at dryer cord the attached to dryer and see if you get 220 the way you discribed it can still be gettiong only 110 .. will bleed back from other side and give false reading.
check the hi limit themofuse on buner.. towards top on burner for continuity... check the burner thermostate, cycleing theomstate on outlet vent.. post if need more help
My dryer only works in one cycle
The Timer Is Bad..Mine Only Heats In Perma Press..This Is After Replacing solenoid Valves And Thermal Fuse, Which Was Good.
7/25/2022 10:11:37 AM •
Roper Dryers
Answered
on Jul 25, 2022
