20 Most Recent
Oster 1.7 L Variable Temperature Electric Kettle Questions & Answers
Kettle is not working. Totally shut off, no lights, no heat , nothing. Kettle only year old doesnt seem right to me that i am replacing a year old kettle. Appreciate you assistance. Mrs Nagy
Mrs Nagy, they do not make things like they use to, it is getting quite common for small appliance to break down after one year, you would almost swear it is built into them to garnade after warranty is up.
the most common problem, the electric cord itself breaks either at the plug or at the entry point at base of kettle, do a wiggle test on the wire to see if it makes a contact, just be careful of a shock hazard, do not do this if you see any bare wire at all.
press the helpful button,
Kettle does not heat. What does the E2 message mean
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
"On" switch blinks, kettle won't heat
In case you are still watching this issue for a solution - I'm afraid my assessment of the company troubleshooting support and of this particular issue is that we are out of luck.I have the same problem. Have downloaded manuals - very little information except for use...ie, don't get them wet.I have contacted the company - they asked me for the same information I gave them in the original troubleshooting request...We bought a new one - fortunately on sale at Target. The blinking light is the normal indication - lack of heat and boiling is the problem.Our new pot boils on both bases...old pot clicks and then just sits there with a blinking light - the light should blink until the temp is reached.I intend to return the old pot to Target and move on....I suspect there is a burned out coil but, it is too hard to troubleshoot and won't be able to be fixed.I suspect that a better (more expensive) pot might have more durable coils...but, we'll see how long the new one lasts.
Not heating up
