20 Most Recent
Acer TravelMate 517TE Notebook Questions & Answers
The hard disk on my TravelMate just died and I
You need something like this
http://www.amazon.fr/Disque-Dur-Interne-2-5-Samsung/dp/B002BXPM84/ref=sr_1_1?ie=UTF8&qid=1297697347&sr=1-1
You won't find a new one cheaper so if it's too much just go to the local computer repair shop, they might have one, recovered from a dead laptop.
Good morning from Guinea BissaI want to know if
yes ...all 510 series have ...including the 517te ...if you do not find it in device manager ..go to bios and set it to optimal factory defaults ..and it will appear without driver (if it isnt installed yet) in device manager or will prompt you that it found new hardware ..
here you will find the driver for it ..
choose the operation system and download...there are 3 available wifi models for this laptop..probably the driver will be one of them ..
http://support.acer.com/drivers_download.aspxplease do not forget to rate..
I have an acer travelmate 517TE. I want to remove
There may be other screws hidden behind plastic concealing covers.
The front bezel can have retaining clips that clip that lock onto the lid and may also held in place with double sided tape.
Use a thin flat blade (careful not to scratch the LCD screen) and slip it between the bezel and the LCD screen and gently prize it away from the screen. Start at the bottom of the screen near the hinges and work along each edge.
The inverter will be located on the bottom edge of the screen between the hinges.
New Hard drive not recognised
This is probably becuase you are trying to use two masters in the same cable...Set the HDD to CS(cable select mode)..and it will detect automatically
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
HOW DO I DOWNLOAD FACEBOOK ON MY TABLET
I found out in Google that this tablet has Windows 8 on it.
You can install Facebook on it by going to the "Microsoft Store".
If it didn't install, check if your operating system is 8.1
Let me know if that helps.
Why will it not turn on
try taking out the battery and unplugging the power cord from it and then holding down the power button for the count of 5 the long way 1 one thousand two one thousand ect.... this will drain back the power from the board and it just might boot after you plug everything back in again and try to power it back on
Pictures of acer travelmate
https://www.google.com/search?q=acer+travelmate&espv=2&biw=1600&bih=769&source=lnms&tbm=isch&sa=X&ei=BHr3VOfTDJL-gwSMmIG4Bg&ved=0CAcQ_AUoAg
How do I find out if I have bluetooth on my laptop
On your laptop go to Control Panel-->Device Manager and then under Network adapters see if you have any Bluetooth Devices install in your laptop.
OR
Click on the Windows Button and in the Search Box at the bottom type in Bluetooth and see if anything comes up. Eg Turn Bluetooth On.
