20 Most Recent Acer TravelMate 240 Notebook Questions & Answers
Unable to switch on WiFi or Bluetooth- is this a drivers problem.
Possibly...is there a hardware switch on th laptop for this?
10/13/2015 5:07:05 PM • Acer TravelMate... • Answered on Oct 13, 2015
Bios password reset
2383A022
5/3/2014 7:42:24 PM • Acer TravelMate... • Answered on May 03, 2014
Bios pasword energi11927
Thanks for telling us your password.
11/11/2013 1:22:40 AM • Acer TravelMate... • Answered on Nov 11, 2013
Powers then shut down
Try another Cord/Charger with the EXACT same power specs. What happens when you push the on button? Fan spins? LED's blink? Ant thing on the screen? Has there been any damage? Drop?
4/19/2013 3:46:31 AM • Acer TravelMate... • Answered on Apr 19, 2013
Powers up, get four beeps, then powers down
System Timer FailureBut it matters what motherboard you have.http://www.computerhope.com/beep.htmThis is the link I use to get started.
4/18/2013 9:21:19 PM • Acer TravelMate... • Answered on Apr 18, 2013
2answers
Factory reset
I think with acer u can use their erecovery management within windows /start/programs/Acer Recovery management/
or you can use the Alt+F10 or F11 at the start up some models vary and that hopefully should prompt u to reset the pc to factory settings, remember to back up you data, you might struggle with some drivers, and make sure you reinstall the security software that you prefer as soon as you are able to connect online. good luck hope this helps
9/13/2012 12:03:50 PM • Acer TravelMate... • Answered on Sep 13, 2012
My Acer 240 screen won't work it appears to be working otherwise
Connect a monitor to the video output, if picture is okay the problem is in the inverter board located under the laptop screen, or the backlight has failed, now if the monitor shows the same symptoms the problem is in the video card ic.
9/2/2012 10:46:00 PM • Acer TravelMate... • Answered on Sep 02, 2012
2answers
How to Disable Acer Travelmate
To disable the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and the bios password will be disable.
Take care.
8/22/2012 11:18:08 AM • Acer TravelMate... • Answered on Aug 22, 2012
My acer travelmate 240 dose not have sound
Ever consider to see if headphone jack works? If this is the case it is possible it is the speaker.Sound card or similar is possible but an expert should be the only one to look for that.
4/17/2012 6:00:49 PM • Acer TravelMate... • Answered on Apr 17, 2012
2answers
Where is the location of the Cmos battery for my
You really need a service manual to try & locate the CMOS battery. With laptops the CMOS battery can be different on each model. These are often located on the motherboard below the keyboard, but a service manual should help you.
11/17/2011 12:55:47 PM • Acer TravelMate... • Answered on Nov 17, 2011
2answers
The Acer travelmate 240 boots up and after the
First try to start in safe mode:
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
10/23/2011 6:39:57 PM • Acer TravelMate... • Answered on Oct 23, 2011
2answers
Same problem but have got acer travelmate 4150
Check on motherbord again you can find cmos cell it is look like round battery cell.
Then pull it for 10 minutes so all bios settings are defaults.
Also you can clear bios with jumper find jumper on motherbord it has 3 -pin 1-2-3 right now jumper is in 1-2 position set it to 2-3 position so your bios is clear.Then again set it to it's original position.
then it not ask for password.
Let me know if you need more assistance.
Thanks.
5/23/2011 9:07:04 AM • Acer TravelMate... • Answered on May 23, 2011
I have a acer travel
blue screen usually happen if there as a hardware conflict.
try to boot in to safemode : http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/boot_failsafe.mspx?mfr=true
try to remember the last hardware software that you have installed, and try to update or rollback it using device manager: http://pcsupport.about.com/od/windowsxp/f/opendmxp.htm just right click on the device and choose properties
or
in the safemode, perform a system restore: http://support.microsoft.com/kb/306084
5/4/2011 5:54:05 PM • Acer TravelMate... • Answered on May 04, 2011
3answers
I REINSTALLED WIDOWSXP PROFESSIONAL IN
After reinstalling the Operating System (windows), you have to install the sound drivers.
TRAVELMATE 240 Drivers
Please visit the above link from Acer support. Download/ Install the required drivers (Cirrus Audio)
Hope it helps! Good Luck!
CreativeTECH
4/27/2011 11:24:35 AM • Acer TravelMate... • Answered on Apr 27, 2011
Screen does not work droped
Yes. You should first disassemble the screen and look for the part number on the back side of the LCD. You must take great care not to damage the LCD bezel. Some of the screws may be covered by rubber bumpers. Then you can order one from EBay. Replacement isn't hard.
4/19/2011 1:48:35 PM • Acer TravelMate... • Answered on Apr 19, 2011
Screen does not work, dropped
yes ofcourse you can get another screen of your laptop.you can caontact to your service provider or you can caontact to any local retailer.........@@@
4/19/2011 6:05:32 AM • Acer TravelMate... • Answered on Apr 19, 2011
Acer TravelMate 240 Notebook Logo
146 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
TravelMate Acer
  • TravelMate Acer
Most Popular Question
change cmos battery
  • Computers & Internet
