20 Most Recent GE Spacemaker GTUP240EMWW 24" Electric Laundry Center with 2.2 cu. ft. Washer, 4.4 cu. ft. Dryer, 9 Questions & Answers
This could be a cycle timer problem but not necessarily. Some other condition could be causing the timer to pause before draining and spinning.
GE Washing... | Answered on May 14, 2019
SADLY WITHOUT SEEING YOUR SETUP I CAN NOT GUESS WHAT MIGHT BE WRONG OTHER THAN THE CONTROL BOARD .THO THE DRAIN OUTLET MUST BE AT LEAST AS TALL AS THE MACHINE IS AND IF IT IS NOT THEN IT QUITE POSSIBLY IS JUST PLAIN SIPHONING THE WATER OUT
GE Washing... | Answered on Apr 18, 2019
CHECK SCREENS IN THE HOSES FIRST , THEN REPLACE THE INLET VALVES
GE Washing... | Answered on Apr 10, 2019
If it's atill under warranty, use it! Call their customer service and tell them what's going on, I bet it's under warranty still and if not they're still extremely likely to help you out! But it sounds like it's overheating and cutting off, by it I mean the motor that turns the drum that your clothes/water/etc. are in. When these electric motors overheat they'll turn off automatically as a safety precaution as to avoid damaging the motor permanently. Once it shuts off, sometimes they'll come back on and work for a while and then just overheat again- it's a vicious "cycle"! Sorry for the corny humor but I couldn't resist. This is common amongst other things like vehicles(fuel pumps & ignition modules are famous for this), many electronics including an iPhone shuts down when overheated until it's cooled down enough to operate safely but it'll overheat again- it's a part failing but holding on for dear life and it's fate is certain. It's possible this could be a simple sensor, call the experts at GE Customer Suppourt, they'll help you troubleshot the issue and get it resolved once and for all, best of luck!
GE Washing... | Answered on Mar 31, 2019
You can go online to searspartsdirect.com and enter your model #. You should be able to find part description, price and part #. Google part #. Should be able to find pretty cheap
GE Washing... | Answered on Mar 29, 2019
GE Spacemaker GTUP240EMWW 24" Electric Laundry Center with 2.2 cu. ft. Washer, 4.4 cu. ft. Dryer, 9 Logo
2 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge potscrubber 900 dishwasher installed
  • Washing Machines
