20 Most Recent
Hyundai 2007 Azera Questions & Answers
E6 fault code Hyundai air conditioner
The E6 error code on a Hyundai air conditioner typically indicates a problem with the indoor unit's evaporator temperature sensor. This sensor measures the temperature of the evaporator and sends a signal to the air conditioner's control board. If the sensor is not working properly, it can cause the air conditioner to shut down and display the E6 error code.
To fix this issue, you may want to try the following:
- Check the sensor wiring and connections to ensure they are secure and not damaged.
- Test the sensor with a multimeter to check for continuity. If the sensor is not reading correctly, it may need to be replaced.
- Check the air filter and clean or replace it if it is dirty.
- Check the evaporator coil and clean it if it is dirty.
- If the problem persists, it is recommended to consult a professional technician to check the air conditioner, or contact the Hyundai customer service for assistance.
It is important to note that these instructions may vary depending on the air conditioner model, so it is best to consult the user manual for specific instructions.
I have a hyundai curved electric wall hung heater, the living flame stopped working how can i fix please
You will need to assess the problem to determine if it is loss of power (circuit breaker or GFCI or overload tripped on the unit), failure of controls (thermostat or switch), or if the heating element(s) or burned out (open circuit or very high resistance on Ohm meter). Once you have that information you can proceed to purchase the necessary part(s) or reset the tripped power safety -- but if it trips again you need to diagnose why that happened.
Replace bulb in hyundai curved glass fire
Two people required for this
Remove fire from wall
Lay fire on its back
Gently slide glass panel towards top of fire and remove. Store glass safely
At the bottom of the fire there is a lamp cover fixed by 8 Philips head screws.
Remove screws and lift off the lamp cover
Slide the flexible rotisserie to one side ensuring you don't lose the rubber grommet
Remove bulb by pulling it out of the holder (force may be required)
Replace with 40 watt G9 halogen bulb. Take care not to touch the bulb with your bare hands
Push the bulb fully home
Refit the rotisserie making sure the rubber grommet is carefully pushed into the slotted hole in the axial bracket
Refit the lamp cover
Lift the fire back onto the wall and replace glass front by lifting onto the lugs either side of the fire.
