20 Most Recent
Acer Veriton 7500G PC Desktop Questions & Answers
"Audio issue"
i already download
If this is a hardware problem then there is little you can do. I'm assuming this the typical no sounds after installing the operating system.
You need to download and run the motherboard or INF drivers first. That let the operating system identify the hardware. Then you run the audio drivers and it will make noise.
If you don;t run the INF then it is shown as a unknown device instead of say your audio card and won't be able to setup the driver. It will say it setup the driver but the device won't work.
DISPLAY ADAPTER
http://www.acer.co.za/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3749&sp=page15e&ctx2.c2att1=23&miu10ekcond13.attN2B2F2EEF=3749&CountryISOCtxParam=ZA&ctx1.att21k=1&CRC=240214786 coppy this link into your browser , then select dekstop in the " select product family menue" choose vitron in the " select product line menue" then u select 7500G in the " select model produt model menue. confirm the product and the drivers would be displayer for u'r download
PS make sure u select the right operating system to correspond with wat u are using before u download. pls rate this solution
Warning your chassis has been opened
Hi need help asap.
I opened my acer desk top box to clean dust out and now has warning chassis open.
I cant access the bios or anything else. Does someone have a suggestion????
Panicking
How do i install an ssd to replace hard drive
The drives will usually come with a utility to copy your old drive to the SSD and make the SSD the bootable drive. You just need to have both drives connected at the same time. Check for download instructions in the packaging with the drive or check the manufacturers website.
Desktop wont start up
Need more info here please. What kind of computer is there any beep. Try to unplug your computer then while it's unplug hit the power button. Then plug Back in see if this helps
Why blinking yellow light and green light infront of cpu
Check if the signal cable for the display is connected and whether there is any kink that may break a wire inside the cable. If the circuit for display inside the computer is broken, most of the time you would hear beeping when turning on the computer.
How can i reset my administration password if i
Use your windows disk and reset the password from there.
2. Boot into safe mode (using f8 at startup) and you will be logged into the built in admin account where you can change the other admin passwords.
3. Use the free Trinity Rescue Kit to recover the admin password.
