20 Most Recent
Initial DTV-172 17 in. TV/DVD Combo Questions & Answers
Power problem "New TV"
If totally dead (both wall current and voltage from RV---someone has to open it to see if fuse/s bad---it will have one for wall voltage (AC) and another for RV voltage (DC) and sometimes also a third in the 12 volt lighter plug if using one.Another possible reason would be the set has been damaged---the circuit board may have been damaged/cracked and needs repair.
Apparently the plug-in tuner is
Copy and paste either one of these links in your internet address bar to take you to the site that carries the tuner:
http://www.amazon.com/Initial-ITM-700-Plug-Portable-Players/dp/B000H6D2NY/ref=pd_rhf_p_t_1
http://electronics.cweb.com/dvd-players~1747/initial-itm-700-plug-in-tv-tuner~61223.htm
http://www.shopmth.com/product/c009/13308581/B000H6D2NY.htm
Power problem
Remove back, reseat all connectors. It is a mechanical interrupt to the relay board causing the problem.
